softail wheel bearing issue
this may or may not be an issue, as i evidently wasn't paying close enough attention when i removed my old bearings, but after seating one bearing, upon putting the other side in, i bottom out on the inner spacer before the bearing hits flush with the outside of the wheel hub. as per the instructions i installed the left side first, and upon putting the second bearing in and torquing it down it just isn't flush. is this normal? bearings i took out are the same thickness as the new ones, so that isn't the issue. here is the 2nd bearing installed. is this right?
2nd bearing (right side, passenger side, brake side, whatever you want to call it)
and this is how the first bearing seated. quite deep in there. just making sure this is all correct.
its a 2010 fatboy lo. 200mm tire single disk brake mounted on the (passenger side) rear
Mikula (06-11-2016)
i don't have any more bearings, after reading so many things saying not to reuse a bearing once you've put pressure on the inner race, should i just go for it or wait another week until i can get some shipped to me?
mo cajun (06-11-2016)
thanks. freakin pit posse. should have known. though when i called the dealer they told me the same thing, left side first. didn't specify disk side.
FLTR2008TRIKE
53
02-12-2012 03:03 PM
