horn
The following 4 users liked this post by ChickinOnaChain:
I have the Wolo Bad Boy horn, and it's given me some issues. The first one started separating. Not uncommon for these, unfortunately. The vibration down there is pretty strong and I don't think they can handle all that.
I went for my horn someone pulled in front of me...silence. It was inside 30 days so I got a replacement. I used clear silicone around the bottom to prevent this from happening again, and so far it's worked.
It's a pretty inexpensive item, so I guess you get what you pay for. I do love how it sounds though!
I had a friend who purchased the Wolo Bad Boy. The first time he used it part of the housing broke off.
I don't have a problem with people hearing my horn. It has a compressor for each trumpet under the chrome plated steel housing. It measured 129 dB when I had it (informally) tested with a sound level meter.
Originally Posted by ChickinOnaChain
I know I've wanted a WoLo horn ever since I saw and heard one. But...what stops me is wiring it because TBH, I suck at it and I'd probably fry the system and I don't use my horn that much. And when I try to, I ALWAYS hit the turn signal.
I actually put some blue electrical tape on my horn button, which helped. The other thing I've done is tap the horn on each ride, to try to embed it into muscle memory.
