Helmet temps
I know the vents in my Schuberth modular work; you can really feel they're open when it's colder out. I've worn it in 100+ degree heat; but it gets hot when you are sitting still. Nice to flip the face up if it's a short stop.
BTW; mine is silver...I choose that hoping it would be cooler "inside" in hot sun.
Originally Posted by Mikey 1450 View Post
I would not get too excited about the vents that allow cool air to circulate. I've had several helmets with these and I have yet to feel any cool air circulating... maybe it works for others.
I also can't feel any air moving, until after my head starts to sweat, then when I move there is a cooling breeze across the top of head. At least as long as I am moving. But after my perspiration evaporates, I can't feel the air anymore.
At least until a few stops, slow speeds, etc. and the cycle begins again. At least that has been my experience out here in the desert heat.
I know this is probably a dumb question but here it goes. My wife needs a new helmet and picked out ones that come in gloss black and matte black. I want to know which would be cooler to wear. I know black is hot but which finish absorbs less heat.
I put both finish types out in the sun for about 15 minutes and checked the temps with an infared thermometer. The gloss read about 14 degrees hotter but is that because it reflects the heat back to the thermometer.
Tomorrow I am putting the helmets out again and checking the inside temps. I'll post my results.
pie plate (07-26-2016)
Thanks for all the replies. I know a white helmet is supposed to be cooler but she hasn't found one she likes in white. The vents in my helmet are just for show as far as I am concerned.
The helmets both were cooler on the inside after setting them out in the sun. The difference was about 20 degrees lower than the outside temp. Not the best scientific test but best I can do.
Just have to keep looking for the one that looks like it will be the coolest to wear.
