Tips for Checking Oil
I just changed the oil in my bike for the first time tonight. I watched a couple YouTube videos to help me, I'm pretty sure I did everything correct. I'm just nervous about how much goes back in. The manual says 3 quarts for a 96' softail custom but the video said that about half a quart gets trapped in the motor and doesn't drain out so I only put about 2.5 quarts in and then checked the oil. Well the oil is so clear I can barely tell where the oil is on the dip stick? Any tricks or thoughts?
On a Softail, I put 2 quarts in and start the engine and let it run until the oil light goes out. I then add a half quart and stand the bike level.
I keep the oil level in the tank just a tad below the bottom of the dipstick filler neck.
I've had a Softail(s) since '88 and once piece of advice that I will give you is to never add oil to the oil tank before you start the bike an allow it to warm up.
Last year my wife only rode her Heritage once but I still changed the oil before I out it away.
This spring, when I dropped it down from the lift I checked the oil (cold engine) and I was about a half quart low (so I thought).
I added the half quart and took the bike in to the dealer (about 9 miles) at an easy pace to get a new set of tires installed (due to age, not mileage).
When we picked the bike up my wife was following me, and with the new tires I was cranking on it a little more on the way home than I did earlier in the day.
My wife came up behind me blowing the horn and flashing her lights.
Apparently I was blowing oil all over her car (and onto her beloved motorcycle)!
Yep, the dipstick had popped out (but thankfully still in the oil tank).
Of all the years that I've had Harleys, this was the first time that I had experienced the "oil sumping" issue.
Received 4,146 Likes
Just eyeball the top of the oil level when you pull that cap off...look down the hole. Much easier than trying to read the dipstick.
It's just an oil bag/oil tank....so it' storage for the oil. Not as critical as engine oil level in a car. Just keep it 3/4-ish to within a bit close to bottom of filler neck..but not up at filler neck.
Yep what he said. It is really no different than reading oil level on anything with a dip stick, new oil is more difficult to see than older darker oil. Good light makes it easier, if the light is dimmer in your garage or where ever you are checking it a flashlight may be a benefit. Even with my 53 year old eyes I can still read it, you will get the hang of it
Received 1,934 Likes
you'll come up with lots of tips and tricks of your own as you go: the washing, all the regular maintenance, any weird noises, etc...before you know it, you'll be offering advice on all this stuff, too. keep at it.
