No rSP code
09-09-2016, 03:39 PM
No rSP code
Had check engine light come on after a ride. Check for codes and found none but did find no rSP in the "P". Bought the service manual only to find check engine light info is in another manual.
Any idea what I should be looking for.
09-09-2016, 04:55 PM
P is for your ECM code.
My guess is you got "no rSP" (no response) is because you didn't have the run/stop switch in the run position.
If you did have it in the run position then check your connection on the ECM because it's not talking.
09-09-2016, 07:05 PM
No rSP
Thanks Bluraven. I'll try it with the run switch on.
myrtle2008
01-16-2013 08:01 PM
INTHERED
07-14-2009 06:31 PM
patsac
02-20-2008 08:32 PM
phreak
07-21-2007 09:17 AM
Sleeps In Trees
12-01-2006 03:11 PM
