New Battery starts then clicks!
1996 ultra classic new battery fully charged it will start once then it won't battery shows 12.7,it will start then the voltage will drop below 7 radio stops working but then turn it off it just clicks put the battery on charge for 10 minutes it will start ,if you idle high voltage stays up let off of the gas it drops all the down to nothing.Help I need some advice please.thanks.
Received 4,317 Likes
Replace it.
10 minutes should be 10 hours more the likely. That low voltage when you hit starter means hopefully the battery is highly sulfated from sitting. Do not use a full size charger on it. If you are still having problems and want me to, I will post a check list to run down with a simple volt/ohm meter to answer all your questions.
https://www.hdforums.com/forum/evo-c...ng-system.html
