Does anybody know by looking at the pics what the front end is on this bike? I want to raise it back up and have no idea what i'll have to order to do it.
Can you measure the fork tube diameter? Confirm whether it's 39mm or 41mm (appears too large visually for 35mm (old stuff, but keeping in mind that the sliders are old stuff...early 80's and earlier))
Reason: said "small" meant "large" :)
Can you measure the fork tube diameter? Confirm whether it's 39mm or 41mm (appears too small visually for 35mm (old stuff, but keeping in mind that the sliders are old stuff...early 80's and earlier))
I will measure them later this week when I get over to the garage.
so what sliders are on there? If I need seals I'll need to know right?
I'm sorry, I couldn't tell you which ones they are specifically. Take it to a good independent Harley repair shop and I'm sure an experienced mechanic will be able to tell you which ones they are.
so I only have a standard caliper and i measured under the triple tree just above the slider and it was 1 5/8 so I'm assuming they're 41mm. I think I need to go buy a set of digitals just to be sure.
