Stuck bolts = Harley-Davidsons
I learned something last week. After drilling out stuck fender bolts on my 03 Fatboy, I ordered a gardner presscot (sp?) fender bolt replacement kit. On the front of the package was a note: "always use never seize" on nylock nuts. Well, previous stuck bolts were assembled a couple of years ago using dry nylocks and were seriously stuck to the bolts. Learn something everyday. YMMV.
Use brass nuts on steel exhaust studs. They won't seize. Use a little bit of "Coppaslip" or equivalent on other fasteners that you don't want to seize.
Use a SMALL amount of blue Loctite on most other fasteners. Use red Loctite only on fasteners that the factory service manual says to do so - and not on any others.
Use quality tools. If a wrench or socket has already rounded off the "right size" fastener once, bin it. Buy a good quality replacement.
Use proper tools - never use pliers to try to undo fasteners, use the correct wrenches or sockets.
Use decent torque wrenches and torque to the mid point of the factory torque settings.
If you do all of the above, Harleys are particularly easy to work on. There are a few fasteners that you will need certain tools (listed in the service manual) to get to. Pay attention to this.
And make sure you do have a factory service manual. Don't butcher anything - step back, read the manual and reconsider.
Is exactly why I buy used machines stock and take money off for modifications. The money and time train leaves the station when you go behind most "mechanics".
Personally, I've found more loose fasteners on Harleys than stuck ones. Then again, there are some fasteners I'll hit with with PB Blaster and let them soak for a minute or two before even trying to crack them. Exhaust stud nuts are one of them. Like the spark plugs on the old Ford 5.4L engines; if you got in a hurry removing them, they'd break off right in the head.
TwiZted Biker (02-26-2017)
I always slightly under-torque...I would rather lose a bolt than shear one or strip a thread, and I've never lost one on any of my 20 Harleys. And, I can't think of anything on my bike that would suffer from the loss of 1 bolt, except maybe a pulley bolt,or comp bolt and I ain't never tooken one of them off.
No. With PB Blaster or Liquid Wrench, and the right tool used properly, I don't have problems with motorcycle fasteners. I learned how to work on machinery the hard way, over a lot of years. I can see how a (mis)used bike could be a problem.
I'll admit right here and now that I never use a torque wrench on anything and I use either red or blue Loctite on everything. Ok....on some stuff I'll use Loctite silver or copper anti seize, depending on the application. I never loose fasteners and I never have an issue with fastener removal. I am a firm believer in coating threads.
