Stuck bolts = Harley-Davidsons
#31
Received 14,146 Likes
Every stuck fastener I have encountered on my current bike has been the result of the previous owner using Red loctite on everything. He even used Red loctite on the brake caliper bleeder screws!
My previous bike I bought brand new and was a breeze to work on. It was a 91 Sportster.
Now if you want to talk about difficult fasteners, go work on a Jeep!
#33
I'll admit right here and now that I never use a torque wrench on anything and I use either red or blue Loctite on everything. Ok....on some stuff I'll use Loctite silver or copper anti seize, depending on the application. I never loose fasteners and I never have an issue with fastener removal. I am a firm believer in coating threads.
#34
For many years I've made it a practice that a day or so before I take on a project I go around and squirt some Liquid Wrench or PB Blaster on all the nuts and bolts I plan to be removing. That gives the penetrant 24/48 hrs. to seep its way in.
Also don't forget that heat is your friend and a little can go a long way in causing expansion and contraction which can help unstick rusted or corroded fasteners.
#35
#36
I've never used Loctite on ANYTHING outside the motor or transmission, and have never had anything come loose. I use anti-seize on the exhaust flange nuts, but I use the Harley-Davidson official flange nuts, which appear to be a slight interference fit, and I replace them when I remove the pipes.
#38
Comp is right hand, clutch is left hand threads.
