Fatvo VS. EVO VS. Twin Cam
RE: Fatvo VS. EVO VS. Twin Cam
Well, I found some general information from SPUTHE...
7-Step Recipe for a RED HOT 100 Cubic Inch Sputhe FATVO Engine
[ul]
1. Start with a Sputhe FATVO crankcase.
2. Add stock Evo 4.25” stroke flywheels.
3. Add Sputhe 3 7/8” forged pistons.
4. Top with Twin Cam heads and cylinders.
5. Cam and carburate to taste.
6. Install in any chassis designed for an Evolution engine.
7. TURN UP THE HEAT. [/ul]
The basic concept of our new Sputhe Fatvo engine is to utilize all the bottom end components of the Evo engine and all the top end components of the Twin Cam engine, all bolting together to build a 100 cubic inch engine.
Sputhe Engineering celebrates our twenty-second year of manufacturing High Performance Crankcases with our new for 2005, fourth generation Fatvo engine.
The fourth generation Fatvo crankcase is cast by a direct gating process from a special aluminum alloy with high percentages of silicon and copper. This superior material is then subjected to a three stage heat-treating, quenching and stress relieving process. The crankcase is then fully CNC machined in-house, including the left case face and deck perimeters.
The fourth generation Sputhe Fatvo case incorporates all of the best features of our big bore Evolution case plus the technological improvements we have developed over the past four years refining our Fatvo engine.
[ul]
Haven't heard much lately, as I haven't kept up with the aftermarket like I used to, but not too long back Sputhe was a well respected aftermarket engine if you wanted a ton of power with rock solid reliability.
This concept seems like it would work.
Regards,
Bill
Regards,
Bill
Curt J
07-31-2013 02:23 PM
