Should Harley have a counter balanced rubber mounted motor?
Old 09-02-2007, 08:29 AM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
Default Should Harley have a counter balanced rubber mounted motor?
Well what do you think a rubber mounted counterbalanced motor? I would be the best of both worlds, no shake at idol and smooth as glass at highway speed.
Old 09-02-2007, 09:04 AM
streeteagle's Avatar
streeteagle
streeteagle is offline
Default RE: Should Harley have a counter balanced rubber mounted motor?
My '07 Deuce does'nt shake at idle & is smooth as glass at highway speed-if it was any smoother it would'nt seem like a Harley. It still vibrates enough to let you know it's a Harley.
Old 09-02-2007, 09:09 AM
dswansbiker's Avatar
dswansbiker
dswansbiker is offline
Harley's are supposed to vibrate. Smooth as glass is not and HD motor that I would want, yecch!
Old 09-02-2007, 09:17 AM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
Rubber-Glides are fer sissies.
Old 09-02-2007, 09:21 AM
MisterB's Avatar
MisterB
MisterB is offline
I could be wrong, but I'm wondering if that's even possible? It seems to me that if a counterbalanced motor got going fast enough, that the centrifical force could cause it to vibrate if the motor was rubber mounted because of the "give", and now the engine is no longer counterbalanced.
Old 09-02-2007, 09:28 AM
100thRK's Avatar
100thRK
100thRK is offline
I want mine to feel and ride like a harley, not a beemer.
Old 09-02-2007, 09:39 AM
BrianDamage's Avatar
BrianDamage
BrianDamage is offline
I would think if it was feasible, they would have already done it.
Old 09-02-2007, 10:10 AM
Cynic's Avatar
Cynic
Cynic is offline
Balancing is a complex subject, especially when you're talking about theour V-Twins. The counterbalanced motor will always be counterbalanced no matter what, doesn't depend much on mount type and it will deal with both primary and secondary imbalance to some degree. The rubber mounts are designed to quash primary vibes (shakes) in the most beneficial plane, usually the vertical plain on a motorcycle. The higher secondary vibes (buzz energy) enter the rubber mounts where it self cancels and to a lesser degreeconverted into heat. I guess you could takethe B-Motor and mount it in rubber bushings like the imports do to get rid of whatever little bit of buzzis left. Why would you want to?
Oh, and that would mean a stiffer chassis, which usually means more weight.
Old 09-02-2007, 10:38 AM
dstockton's Avatar
dstockton
dstockton is offline
ORIGINAL: sonar_chris
You just described a GoldWing or Honda VTX, neither of which I care for. Having had both a counterbalanced Heritage Softail and now an Ultra Classic, I actually like the feel of the rubber mounted motor shaking away all it wants to.
Old 09-02-2007, 11:34 AM
Helix's Avatar
Helix
Helix is offline
I agree with Streeteagle- My 07 FXSTChas just enough Vibs to let me know im on a Bike.No shake at idle and barely a tingle in the pegs/grips on the highway , just the way I like it.
Quick Reply: Should Harley have a counter balanced rubber mounted motor?
