Vance and Hines Quiet Baffles
Can the V&H Quiet Baffles be installed withoutremoving the exhaust system form the bike? I installedthe V&H Big Shots Staggered exhaust on my 2008 Lowrider, but it's a little too loud for my ears. I think the Quiet Baffles will do the trick, but I'm wondering if they can be installed without removing the exhaust from the bike.
Thanks
RE: Vance and Hines Quiet Baffles
Sometimes yes. I have a 2002 Heritage and I was able to get to the screws that hold the tips on and the screws that hold the baffles on without removing the exhaust and without removing the heat sheilds. If you can see the allen head screws you need to take out, you can probably do it without removing the exhaust. It took me less than 30 minutes to change mine and I was pleased with the sound with the quiet baffles.
Tnicean
Tnicean
ORIGINAL: Tnicean
Tnicean
Tnicean
I installed the quiet baffles on my '05 Fat Boy without removing the entire pipe. The quiet baffles will mostly just change the tone not the volume. Before the baffles it sounded ratty and race car like. After the baffles it sounds like more of a loud rumble. I like it alot better.
When installing them be very carefull not to get them in too far, they are very difficult to pull backwards.
Hope this helps and good luck.
Don't forget to remap your fuelpak or other fuel management system when you change your baffles to quiet ones. You are going to have a lot more back pressure and must adjust for it.
Cornel
It is pretty straight forward. Just remove the tips and then the baffles. I do not think you have to remove the whole exhaust system. Ladodgerdog is right about the remap for your EFI because you are going to have a little more back pressure.
lost Again
Did you notice any differnce in performance on the low end or on the top end.My neighbors were thinking of buying me a set for Christmas so they can sleep in the morning(LOL).
Goose
lost Again
Goose
Didnt have to remove the pipes on my SS slipons.Still plenty of sound/volume when you hit it. I'm very happy with the quiet baffles.
ORIGINAL: 4Goose
lost Again
Goose
lost Again
Goose
ShadowforNow
02-25-2019 01:08 PM
