Are the 1450 Evos any good?
Old 02-06-2008, 08:11 PM
sixpack_sid's Avatar
sixpack_sid
sixpack_sid is offline
Default Are the 1450 Evos any good?
I am looking to buy a Harley Softail. Any opinions on which motor is better, the 1340 or 1450?
Also, pretty much most of them I'm finding have oil leaks-is that common?
Thanks.
Old 02-06-2008, 08:47 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Default RE: Are the 1450 Evos any good?
Do not buy a Harley. I repeat. Do not buy a Harley. I can tell by your post that you will not fit. Do not buy a Harley. [8D]
Old 02-06-2008, 08:51 PM
BigJfxdwg's Avatar
BigJfxdwg
BigJfxdwg is offline
LOL, maybe a 1550 shovelhead is better.
Old 02-06-2008, 08:56 PM
titomalu's Avatar
titomalu
titomalu is offline
no, no, a 1340 panhead, or better yet a 1550 pan shovel..... flmao !!
Old 02-06-2008, 09:10 PM
zombie's Avatar
zombie
zombie is offline
They're freakin amazing. Oddly enough a well tuned 1450 evo will run circles around the 1580 and the 1800 flatheads due to the lower crank sidevalves on the flattie with a spleen vent. If you get the 1450 evo, you'll want to check lower wankel bearings, that's what's causing the leaks. A good mixture of JB Weld and Colgate should seal those right up, but not if the flanges are warped. You'll want to make sure that you get the 8-valve transversely mounted L-model with the ladder frame and the intercooled primary along with the 6 in 4 tranny and the jockey clutch with a suicide shifter. They're fckin rockets man.
Old 02-06-2008, 09:16 PM
Sam's Avatar
Sam
Sam is offline
ORIGINAL: zombie
Yeah.............but does the Colgate need to have Fluoride in it??????????
Old 02-06-2008, 09:18 PM
zombie's Avatar
zombie
zombie is offline
ORIGINAL: Sam
ORIGINAL: zombie
Yeah.............but does the Colgate need to have Flouride in it??????????
Only if it's synthetic.
BigJfxdwg's Avatar
BigJfxdwg
I keep telling the wife I need my lower wankel bearings checked and she just laughs and walks away.
Old 02-06-2008, 09:21 PM
1of2's Avatar
1of2
1of2 is offline
"Moderator"
Is the 1450 evo motor faster then my TC88? Maybe I should upgrade?
Old 02-06-2008, 09:22 PM
zombie's Avatar
zombie
zombie is offline
ORIGINAL: BigJfxdwg
Go figure...women just don't understand all this mechanical stuff
