Changing Derby Cover
Old 02-21-2008, 08:44 PM
HDluxy's Avatar
HDluxy
HDluxy is offline
Default Changing Derby Cover
Replacing Timing cover, Inspection Cover, and Derby Cover. Do I have to drain the oil to change these or just lean the bike to the side when removing? Do I need to replace the gaskets? Any issues with leaking after changed? Seems pretty basic however my inspection cover was blowing a little oil vapor after the dealer changed out my inner primary. Twin Cam 88 with 5000 miles on it. I want to upgrade all three.
Old 02-21-2008, 08:58 PM
KSCruiser's Avatar
KSCruiser
KSCruiser is offline
Default RE: Changing Derby Cover
I just leaned my bike over when I changed the derby cover (actually had my neighbor lean it over while I changed it). Regarding the gasket, when I bought the cover the dealer told me...if the gasket comes of with the cover replace it, if it stays on the bike go ahead and put the new cover on. I bought a gasket just in case, but didn't need it. Can use it later down the road when the fluids are changed again.
firemankrug's Avatar
firemankrug
firemankrug is offline
I changed my derby cover on my 07 with it on the jiffy stand, the primary oil is below the lowest point on the opening. I don't have a inspection plate so I can't help you there. There is nothing behind the timing cover to worry about, its just for looks. I would say yes to changing gaskets. Its a simple job, go for it.
Old 02-21-2008, 09:07 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Also, if you do need to change out the 'ring gasket', Harley now makes a 'solid ring gasket' that makes installation much easier.
With the new solid gasket you no longer have to position the old style ring gasket in the groove and hope it stays in the correct position.
For example, here is the newer 'solid ring gasket' for the TC Softails..
Old 02-21-2008, 10:09 PM
YesterdaysCorn's Avatar
YesterdaysCorn
YesterdaysCorn is offline
Yeah not crazy about that new style gasket.....I had to usethe frisby when I changed to an after market derby cover.
Old 02-21-2008, 10:16 PM
firemankrug
The new "Frisbee" gasket seems to do the job though, I'vepulled the derby cover twice, changed the gasket both times,and no signs of leakage.
Old 02-21-2008, 10:31 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
ORIGINAL: firemankrug
Ditto that. Looks like it does the job...covers everything.
Old 02-21-2008, 10:37 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
I dont even change the frisbe gasket, I just reuse it and havent had a leak yet.
Chris
Old 02-21-2008, 10:43 PM
biz44's Avatar
biz44
biz44 is offline
ORIGINAL: sonar_chris
Chris
+1....I have had the derby cover off three or four times on my )3', and reused that gasket each time with no sign of oil at all. I do however change the inspection cover gasket each time....I have never had any luck with reusing those over the years.
Old 02-21-2008, 10:44 PM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
As long as it don't leak works for me ...
Quick Reply: Changing Derby Cover
