Oxygen sensor torque value?
RE: Oxygen sensor torque value?
Hi, according to the Harley07 Dyna manual the torque setting is 29-44 ft lbs (39.3-59.7nm). It does say to an anti-seize on the threads which is a good idea as they can be a bitch to remove.
Hope this helps.
Hope this helps.
Received 4,294 Likes
Does the torque value take in consideration the use of the anti-seize? Is this anti- sieze a high temp variety? The ignitors in the jet engines I was familar with used a hi-temp but were also safety wired to stay in place.
ORIGINAL: cornishman
Hope this helps.
Hope this helps.
Tedjay
03-09-2013 10:27 PM
