how to tighten clutch hub nut
hey, just wanted to ask... I tightened my clutch basket nut by hand, and it seems so tight I cant push my kick down. If I loosen it off a touch my kick will push down ok.... I just put in a sputhe 5 in 4 tranny. It only has a little oil in it, the clutch is dry from being out, and I used grease to hold the needle bearings while i slipped the clutch on. So when reading your post about Impacting the nut on, obviously it needs to be tight.
Maybe when the primary oil is in, and the tranny is full it will be a lot better? or did I forget something? The manual says 80-100 ft pounds I dont have that torque wrench
Thanks
(81 Lowrider)
Thanks
(81 Lowrider)
When I was messing around earlier today for some reason I pulled ,or pushed on the bendix lever to see how the new hub lined up,I got a big surprise because it did try to start . Scared the crap out of me,couldnt believe that happened with the key off. Snowing now No big rush!
where it shouldn't have been, and chopped it clean off!! Index finger too!
Yikes!
I bought it assembled. They said the gears were good, and they changed the throw out bearing I did look in it from the top cover and the gears did look really good, they left that cover loose so I could look, not that I really knew what to look for
Its hydraulic clutch tranny btw if that might matter...
Maybe its in between shifts or something? that kinda not sitting right maybe?
I did have to file a spot on the threads of the shaft cause there was a ding. Maybe in shipping it got dropped on the shaft and jammed something?
geez maybe I should just hammer it with the impact....
When I took the clutch off the old 4 speed, I used the impact but the nut came off without much trouble. The clutch wasnt hard to get off the shaft either. I wonder if the last guy left it not so tight too. It is "fairly" tight where it will still move ok when I push the kicker, maybe thats good enough with the lock tab on the nut, and its a lefty nut too...?
The gears in there looked really good.
Im going to remove the tranny and have a look inside. has to be something inside jamming up.
It seems torquing on the main shaft has made it jam. That bothers me... hopefully it will be something just needs simple adjusting. I checked out some youtube videos on dissasembly, and it accually looks fairly strait forward. Ill let u know if I find it
guess I'm showing my age but when I was working on my old Pan or Shovel, whenever trying to remove or tighten the clutch hub nut I used a homemade tool that me and everyone I knew had.
We would take and old clutch friction disc and a 18" piece of flat steel. Drill two holes in the "Handle" and the clutch disc and bolt them together. Now slip the improvised tool over the clutch hub fingers and rotate the hub until the handle rested on the ground. Install your socket and wrench (or impact) and have at it. I still have my clutch hub nut tool in my tool box.
Went to my Dealer and asked to purchase the 'primary locking tool.' Was asked how many people I thought asked for that in last year. I shrugged my shoulders. "One," he stated. "You." "Use an impact wrench." I did and have had no problems with nut.
Fureek (05-15-2019)
ok I took the tyranny back out. Looks like there were 2 different issues. I opened the top, and turned the shift drum, and it isnt locked up anymore.
I could see on the sprocket side of the inner primary some small scrape marks where the sprocket nut looked like it was hitting. There are grinder marks there where someone had ground away some material so the sprocket wouldnt touch and bind up with the 4 speed. It must not be the original primary cover. I ground it down a little more where the marks were and tightened everything up with the impact. Working great now. (oh yeah I glued in the key)
Thanx guys for all the think tank
