Hanging Guardian Bell
Old 04-06-2008, 09:44 AM
mbjam359's Avatar
mbjam359
mbjam359 is offline
Default Hanging Guardian Bell
I was given a guardian bell as a gift and want to hang it on my FXSTC today. I was wondering what is best to use to secure it to my bike. It came with a leather type string and I was wondering if that will work or what do others use? Thanks
Old 04-06-2008, 09:46 AM
Deluxechuck's Avatar
Deluxechuck
Deluxechuck is offline
Default RE: Hanging Guardian Bell
I have seen the leather used most of the time. Or you could use some kind of banding wire. It may rust a bit, but its your choice.
Old 04-06-2008, 09:49 AM
kwas's Avatar
kwas
kwas is offline
I've used a small plastic wire tie and then clipped the excess off instead of the leather string. I also kept it a little loose so to leave it swing room......
Old 04-06-2008, 09:58 AM
oldairboater's Avatar
oldairboater
oldairboater is offline
I used nylon cord as a back up to the leather. I hung my bell from the bottom of my floorboard but it kept dragging the ground in tight curves. I moved it higher up on the bike.
Old 04-06-2008, 09:59 AM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
I also went with a zip-tie instead of the leather string.
Old 04-06-2008, 10:00 AM
ranger56528's Avatar
ranger56528
ranger56528 is offline
I used a zip tie along with the leather..Wrap the leather around the zip it looks better.
Old 04-06-2008, 10:02 AM
zukeeper's Avatar
zukeeper
zukeeper is offline
mine is ...or was leather. not even sure if its still under there any more[&:]
Old 04-06-2008, 10:19 AM
mbjam359's Avatar
mbjam359
mbjam359 is offline
Thanks guy's I was concerned the leather might not last long.
Old 04-06-2008, 11:06 AM
TXCOMMISH's Avatar
TXCOMMISH
TXCOMMISH is offline
String two small key rings together. Loop one to the bike, one to the bell. Never will rust or come off.
Old 04-06-2008, 11:44 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Da Gumpmeister is offline
For a 'normal' sized bell, just use key rings as posted. They work great, do not rust and do not break.If you have a "large" bell , then use a "large" leather tie. (See pic) http://i246.photobucket.com/albums/g...r/PICT0950.jpg
Quick Reply: Hanging Guardian Bell
