Low fuel light
Low fuel light
Put a new set of silver faced gauges in my fairing when I had it painted this spring. The new speedo's low fuel light comes on when the tank is completely full for about 25-30 miles then goes off. Doesn't come on when its near empty - took it down to less than 1/4 gallon and no light
The new gas gauge seems to be accurate
Think it is a sensor in the tank ? Worked perfectly with the stock gauge.
Suppose the new gauge is bad ?
RE: Low fuel light
ORIGINAL: Fishguy001
I had the sme problem when I went to a LED gas gauge....There were two sets of instructions, one for EFI and one for carb. We ahd to splice into the wire and run a jumper wire. This was a year or so ago so it's a little hard to remember. My low fuel light only came on when it was full, just the opposite of the way it was supposed to work.
What kind of gauges did you install? Matbe you can go online and check for revisions of directions for installation ie. carb vs EFI...
Good luck
RE: Low fuel light
ORIGINAL: RoadKingRon1
Good luck
Good luck
