Pop, pop, pop, pop.....
Old 08-16-2008, 08:10 PM
White-Trash's Avatar
White-Trash
White-Trash is offline
Default Pop, pop, pop, pop.....
Had my bike dyno'd and it pops like an S.O.B. on decel and sometimes between gears. Don't know if i like this or not.
Old 08-16-2008, 08:13 PM
thundergod's Avatar
thundergod
thundergod is offline
i would take it back they should get rid of the pop.
Old 08-16-2008, 08:49 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,307 Likes on 2,356 Posts
Well, if you have an EFI bike with a stage one, sounds like they leaned it out on you to meet EPA requirements. Another possibility is if you had an exhaust put on you may have a leak and it's sucking air and igniting the exhaust gases.
Old 08-16-2008, 09:14 PM
jkoch09ultra's Avatar
jkoch09ultra
jkoch09ultra is offline
If you have a PC111 you can change the numbers in the 0 throttle column to 20 above 1250 rpm range. Like magic.
Old 08-16-2008, 09:50 PM
dope_man_21's Avatar
dope_man_21
dope_man_21 is offline
+1 take it back to the dyno shop, make them fix it!
Old 08-16-2008, 10:22 PM
White-Trash
It's the screaming eagle race tuner.. I can't make any adjustments myself.
Old 08-18-2008, 09:52 AM
White-Trash
I'd called them to let them know about the popping. He asked what exhaust I had and I told him V&H. He said that was normal for V&H, but to bring it in and he would have a tech test ride it.
Old 08-18-2008, 09:54 AM
Bluzmn59's Avatar
Bluzmn59
Bluzmn59 is offline
It is not normal for V&H. They need to get it right.
Old 08-18-2008, 10:01 AM
R1Geezrglide's Avatar
R1Geezrglide
R1Geezrglide is offline
My dealership tunes these systems everyday with no 'pop'. The only issue comes from overly open systems attached to mild builds. The normal VH system is not a problem.
Old 08-18-2008, 10:22 AM
Double00Aught's Avatar
Double00Aught
Double00Aught is offline
V&H does not 'pop', take it back and make them fix it.
Quick Reply: Pop, pop, pop, pop.....
