Wolo bad boy chrome air horn
Old 10-22-2008, 12:12 PM
brwelborn's Avatar
brwelborn
brwelborn is offline
1st Gear
Default Wolo bad boy chrome air horn
This horn looks like a good value and it is REAL LOUD. Has anyone had experience with mounting this puppy on the Harley stock horn mount?
Old 10-22-2008, 12:47 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,434 Likes on 874 Posts
I have in & love it. Very loud. You need to hook it up directly to the battery with a relay. Also Stebel is coming out with a new cover & it's the same horn as the Wolo.
http://www.thepropad.com/p-84-mini-b...ming-soon.aspx
Old 10-22-2008, 01:13 PM
brwelborn's Avatar
brwelborn
1st Gear
Wow. It says it will plug right up to the pigtail that goes to the stock horn.... that is not correct?
Old 10-22-2008, 01:28 PM
golfblues's Avatar
golfblues
Not correct. It comes with a relay that must connect directly to the battery. Very simple. Also, get some black wire protector for the wires from home depot or radio shack.
Here's a pre-wired kit. It makes it easier http://www.twistedthrottle.com/trade...view/2867/539/
Old 10-22-2008, 03:35 PM
brwelborn's Avatar
brwelborn
1st Gear
Thank you so much.
Old 10-22-2008, 04:39 PM
bigskyhd's Avatar
bigskyhd
bigskyhd is offline
Good Poop, I've got to get one of those air horns. The deer are thick this time of year....
Old 10-22-2008, 06:53 PM
monster fxstc's Avatar
monster fxstc
monster fxstc is offline
Man, you don't want to use that horn on deer...they're likely to freeze up in front of you about the time you do.
Old 10-23-2008, 12:51 AM
karz10's Avatar
karz10
karz10 is offline
not to hijack, but does anyone know if those deer whistles work to keep em away from ya?
Old 10-23-2008, 12:55 AM
GT_RoadGlide's Avatar
GT_RoadGlide
GT_RoadGlide is offline
I like it!
Old 10-28-2008, 09:45 AM
gmc's Avatar
gmc
gmc is offline
I guess there is no problem with vibration mounting these on the stock bracket?? I called the toll free no and he seemed to think it should be mounted to the frame?
I just got mine and was supprised had to run wires since all adds say just plug in but then instructions in pkg say for MC to wire in the relay. On e-bay there is an AH! which suppose to put out 142DB vs BAD Boy 118DB. Anyone have a comparisson, they look the same.
Quick Reply: Wolo bad boy chrome air horn
