Primary Oil Level
Old 04-13-2009, 02:12 PM
Donald A's Avatar
Donald A
Donald A is offline
Default Primary Oil Level
Before the flames come on:
I have checked the factory owners manual and it is not clear. I have also searched and could not find an answer.
When checking the primary drive oil level I know it is suppose to be at the bottom level of the clutch inspection opening, or there about.
Is the oil level checked when using the jiffy stand or setting level?
2004 Road King.
Old 04-13-2009, 02:42 PM
kjmorgan's Avatar
kjmorgan
kjmorgan is offline
Flames? On this forum?
Bike should be level when checking primary. Put it on a lift or have someone hold bike level.
Old 04-13-2009, 02:44 PM
Juno's Avatar
Juno
Juno is offline
Nice!
Old 04-13-2009, 02:57 PM
Intrepid175's Avatar
Intrepid175
Intrepid175 is offline
The manual for my 09 Ultra, page 160, says;
1. Ride the motorcycle until the engine is warmed up to normal temperature.
2. Stand vehicle upright on a level surface, so that the primary chaincase is level.
3. Remove five screws to free clutch inspection cover from primary chaincase cover.
4. Remove seal ring from clutch inspection cover and discard.
5. If the fluid level can be seen, it is adequate. Otherwise, pour enough GENUINE Harley-Davidson FORMULA+ TRANSMISSION AND PRIMARY CHAINCASE LUBRICANT (Part No. 99851-05, US quart) in through the clutch inspection cover opening until it is visible along the bottom portion of the clutch assembly.
6. Refer to Changing Chaincase Lubricant to install seal ring and clutch inspection cover.
Sounds simple enough. The capitalization shown is as it's printed in the manual. Please be sure to note the GENUINE Harley oil!
Good luck & Ride Safe,
Steve R.
Old 04-13-2009, 03:01 PM
Donald A's Avatar
Donald A
Donald A is offline
I had the bike on my stand and started filling it to the bottom of the inspection hole, after putting a quart and half it still was not at the bottom of the hole. I stopped and read the owners manual and it said to put 32 oz, 1 quart, thus my confusion.
Old 04-13-2009, 03:03 PM
comaman2's Avatar
comaman2
comaman2 is offline
i always fill until the oil runs out from the inspection hole,usually takes about 36 ozs. seems to work just fine for me
Old 04-13-2009, 03:38 PM
Mandog's Avatar
Mandog
Mandog is offline
Your putting in way too much. You want it just visible towards the bottom of the clutch. NOT UP TO THE DERBY COVER OPENING.
Your bike is going to shift like a turd with that much fluid in there.
Old 04-13-2009, 03:45 PM
jefnightrain's Avatar
jefnightrain
jefnightrain is offline
I thought harley's were supposed to shift like a turd.
Old 04-13-2009, 03:49 PM
electraride2's Avatar
electraride2
electraride2 is offline
a quart and a half is just right....just did mine and it's not shifting like a turd...
Old 04-13-2009, 03:50 PM
cowboy1's Avatar
cowboy1
cowboy1 is offline
I always thought so but never heard any turds of mine clank like that...LOL...
As for the fluid, make sure its touching the bottom of the clutch assembly..kinda like from just after 5 to just before 7 on a clock...if you ahve any confusion, drain it as put in what it calls for...
Quick Reply: Primary Oil Level
