Corbin Backrest - Quick removal
Old 04-22-2009, 07:32 PM
nextorion's Avatar
nextorion
nextorion is offline
Default Corbin Backrest - Quick removal
Just wondering if the Corbin driver's backrest requires seat removal to detach or it is relatively quick and easy? I've got a Mustang driver's backrest for the bagger that I can simply take on and off in a snap. I am thinking about adding a Corbin backrest to the softail, but it appears that you might need to remove the seat and need a wrench to it to get it off. I'd like to only use it occasionally, so easy on and off would be plus. Thanks in advance
Old 04-22-2009, 07:54 PM
firefighter3666's Avatar
firefighter3666
firefighter3666 is offline
The Corbin backrest is secured to the seat with an allen head screw. On my dual tour seat, the backrest can be removed from both the front and rear location without removing the seat from the bike. This will require the use of an allen wrench.
Old 04-23-2009, 03:02 PM
Splatter's Avatar
Splatter
Splatter is offline
It must depend on the particular Corbin seat. I have the classic solo and it has to come off the bike to attach/remove the back rest.
Old 04-24-2009, 07:12 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
You need to remove the seat to remove the allen screw. Or leave the allen screw out when you install the backrest, and it will just slip on and off. Makes it easy to steal too.
GalvTexGuy
2014+ Touring Models
06-09-2016 04:57 AM
Ed G. Price
02-04-2014 09:33 AM
buckwheat
05-07-2008 08:55 AM
carpetride
12-07-2007 07:28 PM
mndemohead
12-30-2005 05:02 PM
Quick Reply: Corbin Backrest - Quick removal
