Noisy twin cam
Old 05-22-2009, 06:22 PM
SportsterBob's Avatar
SportsterBob
SportsterBob is offline
Originally Posted by 1peter
It is mostly comming from the pushrod side and it is very much like rocker noise but its hard to pinpoint. its just an all over rattly sound (sounds like a sewing machine LOL) and if I wasn't concerned about cam chain tensioners I probably would'nt worry.
Is your motor stock? To my knowledge the Twin-Cams in stock form do not have adjustable pushrods to adjust freeplay but I'm no expert on Twin-Cams...
If the clatter goes away after time it is not a cam chain issue...You may be alright so long as the clatter is not permanent!
Old 05-28-2009, 10:48 PM
davsel's Avatar
davsel
davsel is offline
Stage III
My rpm dependent clatter turned out to be a loose breather bolt holding the air cleaner backing plate to the engine. Drove me nuts for 1000 miles before finding it was a simple fix. Worth a look.
Old 05-29-2009, 08:11 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
If it only happens on cold startup, it might be oil pressure related. If you are using one of those ulta-high filtration oil filters, that could be the cause.
Old 05-29-2009, 09:20 PM
AZ Rider's Avatar
AZ Rider
AZ Rider is offline
Harley engines making noises? I'm shocked!
Old 05-29-2009, 10:51 PM
JDB's Avatar
JDB
JDB is offline
Default 13,000
Its just now getting loose and ready to run.
HDJaco
Engine Mechanical Topics
04-28-2016 07:38 AM
harley#1
04-06-2016 08:27 AM
tmanbuckhunter
EVO
255
02-27-2014 04:12 PM
1peter
Exhaust System Topics
06-08-2009 02:30 AM
tfw309
01-23-2007 10:00 PM
Quick Reply: Noisy twin cam
