2007 sportster 883 leaking oil
Can anyone give me any advise on my bike, its leaking oil from the oil cap while i'm driving onto my oil tank, and is leaking oil from under the crankcase when i let it set, if anyone can help me out i would appreciate it.
Thanks
Thanks
Tom here. Sounds like a warranty issue to me. Take it to the dealer. Even if your warranty is up you can sometimes get them to take care of such issues.
Regards,
Tom
Harley Goodies
Regards,
Tom
Harley Goodies
I would probably check the oil level in the tank... sounds like to me that its too full... You may have done it to specs... but Sportsters like a little less oil than recommended... I do three quarts....
It could be the seal on the dip stick... but my hunch is too much oil...
Got over 30k on an '05 Sportster and been running three quarts since I encountered the same problem when I used the recommended amount when it was new... after I adjusted the amount... never had the overflow problem again...
Charlie D.
Charlie D.
My wife has an '06 883. Overfilling the tank will cause it to blow out the cap when you run her hard. Prior to that, I found a leak on the plastic oil tank along a seam. It was dripping on the left cover and finding it's way to top of the rear brake fluid reservoir. Tank replaced under warranty.
Take the side covers off and make sure the tank isn't leaking. If not, I'm guessing tank is overfilled.
Received 4,284 Likes
The older (late 99 model) models oil tank drain tube fits on a plug under the frame and is clamped off so that it won't leak. That could be the cleak under the bike. Did some just do an oil change?
