Newbie question - What is an FXR?
Old 05-16-2006, 10:47 PM
Jovimon's Avatar
Jovimon
Jovimon is offline
Default RE: Newbie question - What is an FXR?
The 1975 bike is a FXE. Had one long ago...
Old 05-17-2006, 12:26 AM
Snobal's Avatar
Snobal
Snobal is offline
What is an FXR? The best bike HD ever made!
I got a '91 FXRS-Con the summer of '90 (one of the first ones off the truck) - the dealer said, "If you have any problems with it, bring it back, it has a warranty." Never needed the warranty. Ten years and 60K+ miles later, I screwed up and traded it for a twin-cam (but got more $ when I sold it than I paid for it in 1990).
The FXRS-Con was a convertable model: quick disconnect windshield and saddle bags. With windshield and bags, it was a great touring bike.
Neat features:
- It ran great! If you ran at the speed limit (55 mph at that time) the bike got well over 50 MPG (typically 55 to 56 MPG).
- The oil tank had a "view window" so you could see if you needed oil - did not need a dip stick. The oil filter was under the bike, well protected, and came out like a car filter -- NO MESS!
- The seat flipped up for access to the oil tank & battery - no screws to remove and instant access.
- Rubber mounted engine - was smooth as a "flying carpet" between 50 mph and 70 mph.
- Most folks I knew got over 100K before thay had to do any engine work.
- The frame was lite weight and I was told it was "hand made" --- and too costly for HD to continue making. They went to the Dyna with heavy, robot made frames, (and lost the smooth ride!)
Design problems:
- The base gaskets started seeping oil after about 50K miles - but a cheap, no-brainer to replace.
- Alternator plug could work loose - a simple spring clip solved that problem
Mine cost about $10K new in '90. When they offered the limited edition models after the FXR was replaced by the FXDs, the FXRs were about $20K --- and worth it!
JMHO
Old 05-18-2006, 01:00 PM
JJJL's Avatar
JJJL
JJJL is offline
6th Gear
Thanks for all of the responses and the history lessons on the FXR! What a great knowledge base. I'll keep asking and learning. Thanks again!
BluBeaSSt
05-07-2015 04:42 PM
Vermontster
10-12-2013 08:17 AM
ph308
06-25-2012 10:29 AM
Mr.Grumpy
08-26-2008 09:17 PM
painxxx
04-06-2006 01:52 PM
Quick Reply: Newbie question - What is an FXR?
