New HD Oil?
New HD Oil?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
I also notice that the Syn 3 now states "full" synthetic oil. I don't recall the Syn 3 advertising as "full" synthetic. Something new?
Just looked at one of my old bottles, says, Synthetic oil, nothing about full syn.
Ok, hold on, the above web site show us a syn bottle of HD oil that says its a blend right on it, not that its a true 100% sny oil, I think Ur getting mixed up...
At $7.95, its less than what the older SYN 3 oil sales for...So Unless I didn't see the bottle Ur talking about, One that says 100% syn oil, If so and they have come out with a true 100% syn oil It would more than likely be higher than the older sny3 in the light brown bottle that they had till now..
Since HD refuses to publish any API specs or certifications on their lubricants like 99% of the rest of the industry does. I refuse to buy their lubricants.
Then you always get the implied warranty denial threat by many dealers if you don't use their products. Not a trusting way to do business with loyal consumers IMO. Just a real turn off for me.
[QUOTE=KBFXDLI;5402595]Since HD refuses to publish any API specs or certifications on their lubricants like 99% of the rest of the industry does. I refuse to buy their lubricants.
That Hugo Chavez is one smart ****. Thanks for bringing that up.
[quote=KBFXDLI;5402595]Since HD refuses to publish any API specs or certifications on their lubricants like 99% of the rest of the industry does. I refuse to buy their lubricants.
<<<<<<snip>>>>
One of the reasons why I don't use their lubes as well. I want to know what base stocks it comes from, the VI, shear, and total base number as a minimum.
The other reason is I wouldn't use CITGO/Chavez oil if it was the best lube on earth anyway....
Cheers,
V2Evo96
<<<<<<snip>>>>
Cheers,
V2Evo96
Screamin' Eagle® SYN3® Full Synthetic Motorcycle Lubricant - SAE 20W50
TESTED-CERTIFIED for use in Harley-Davidson® engine, primary chaincase and transmission applications, the new Screamin' Eagle® Full SYN3® Synthetic Lubricant makes changing and topping-off fluids a simple, one-product process. Developed with a proprietary three synthetic basestock formula, Screamin' Eagle® SYN3® Lubricant is formulated to provide for long-term protection and engine cleanliness requirements and to provide superior high-temperature protection for high-output engines. SYN3® is formulated to maintain the coefficient of friction for proper clutch operation and to provide the proper lubrication to the primary chain drive. In addition, SYN3® is designed to provide the correct lubricity for the anti-wear requirements of transmission gears and for improved seal protection. This formula is approved by Harley-Davidson® for use in all stages of engine life and is not detrimental to the break-in stage of engines.
Important Information on Screamin' Eagle Synthetic Motorcycle Lubricant - SAE 20W50
99824-03.00QT
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
1 Quart Bottle
Formulated for Harley-Davidson® Engines, Transmissions and the following Primary Chaincase applications: '71-later XL, '83-'84 XR1000, and '84-later Big Twin models with wet-type diaphragm spring clutch.
MSRP US $9.69
It says new Screamin' Eagle® Full SYN3® Synthetic Lubricant. I just don't recall it saying this. I could be wrong. Also it is not new has been out a few years now.
99824-03.00QT
1 Quart Bottle
MSRP US $9.69
DHart
Oil Archive (no new posts)
10-06-2009 11:28 AM
