Upgrad to 95 Inch
Upgrad to 95 Inch
Ok here I go. I have a 2006 Harley Electra 88 inch I am looking to make some upgrades. The first thing I would like to know is what is the difference between boring the stock cylinders, and buying a 95 inch kit with piston and cylinders. Are the kit cylinders thicker? Next I am thinking Andrew gear 26 cams and adding a fueling oil pump and camp late, and some head work.
Nope, same cylinders just already bored.
Most important thing to do is make sure all parts compliment each other when planning a build. What tuner do you plan on using?
I didn't need a cam plate or a new fuel pump unless you have a problem currently but I did the Andrews 26G cams in 2005 on my 2004 Ultra and this winter I am having the shop bore the cyclinders and adiing Flattop pistons and Heads custom ported for this application. With out the head work the bike peforms alright but the power is all done around 4200 RPM.
I dont think the cyl are thicker, U'll like the 26's, the fueling I really dont know, In my 96'' I didn't do any thing to the oil pump...nor the heads..
Go to Softails section, Sticky thread page 1, Dynos Numbers for Softails, 1st post, I posted my dynos on the 26 cams...
04 Ultra Classic 1450 Stock Heads, 26G Andrews cams, SE Air breather, Vance&Hines Du
Here is my Dyno Sheet and I ridden it like this for 4 summers but it is time for more~
Andrews 26G cams, SE air Breather, Vance & Hines Headers with Samson Wide Oval Slip-ons on a 2004 Ultra Classic with stock Cylinders 1450cc and Stock Heads with Power Commander. I will have head work, Throtle Body polished and pistons next over the winter....
If you are thinking of a big bore KIT, look on eBay. House of Harley (south of Milwaukee) has been selling them for around $550 or so I think.
Howdy,
Here is the reason I went with the Feuling pump and cam plate in my 95 C.I. build,
Billet Plate
The Feuling plate offers much more of a compatible system over the H-D units,
I had my cylinders and heads sent to Branch-O'Keefe for their expertise, cylinders were bored and the heads were re-worked, 9:5 to 1 CR with Branch pistons and Cometic gaskets
Feuling pump and cam plate, S&S cam Gear Drive with Branch cams,
Stock pipes for low end grunt and Kerker Mufflers with the "Mikuni Baffle"
True Duals would have most likely given me 100 HP, but I ride two up with a lot of luggage so I preferred the low end grunt,
Good Luck,
Billet Plate
Good Luck,
nightrider05
Exhaust System Topics
01-10-2013 09:00 AM
KCMooose
14
12-17-2011 05:15 PM
