drain my fuel tank
12-12-2009, 11:55 AM
drain my fuel tank
need to drain my fuel tank on a 1996 FXWG , i took the fuel line off and turn the petcock on and have no fuel draining out ??? What do i need to do to get it to drain ??
12-12-2009, 11:57 AM
12-12-2009, 11:59 AM
12-12-2009, 12:04 PM
If the petcock has a vacuum line attached to it, you need to supply a vacuum to that line in order for the petcock to flow.
Otherwise, use a siphon hose.
12-12-2009, 03:35 PM
Siphon hose is the easiest and cleanest way to drain it.
12-12-2009, 04:07 PM
got r done with a siphen hose. Thanks for the input. I guess iam just use to an old style of petcock
12-12-2009, 04:08 PM
Vacuum activated valve back side of the petcock. You have to pull a vacuum on it.
12-12-2009, 04:10 PM
There is a vacuum hose on the BACK side of your petcock. You will have to pull the hose off and connect a hose and vacuum gun to it.
12-12-2009, 06:51 PM
I had a petcock once. My ex ended up with it in the divorce.
Whitey1
EVO
20
07-27-2022 09:04 AM
mlrailguy
02-06-2015 01:30 PM
kbuckz06
04-09-2010 09:55 AM
mvinc01
03-14-2007 01:38 PM
HarleyRiderOrlando
Exhaust System Topics
03-18-2006 09:56 AM
01 ,
2008 ,
2009 ,
classic ,
davidson ,
drain ,
draining ,
fuel ,
gas ,
harley ,
harleydavidson ,
petcock ,
tank ,
ultra ,
vacuum
