DOes this Train do Wheelies?
Old 03-24-2010, 01:10 AM
eliems's Avatar
eliems
eliems is offline
Default DOes this Train do Wheelies?
I have great fun running for blocks on the back wheel of my WR450 dirtbike but lately (winter hybernation for the Harley at the moment), I have been thinking about the Night Train doing wheelies.
Would this big pig (Hog) come off the ground or just lay some rubber? Bike is stock but for stage one pipes and breather.
http://www.youtube.com/watch?v=9U5RfLZlfoU
Looking at this Roadking pooping up like that has me wondering.
Old 03-24-2010, 01:15 AM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
Probably so if you have the skills to do it ???
Old 03-24-2010, 06:21 AM
madjimmax's Avatar
madjimmax
madjimmax is offline
Sure will without a problem, But unlike a dirtbike if you screw up it will be very costly. But if you have the ***** go for it and get a vid so we can see to.
Old 03-24-2010, 06:40 AM
soundman's Avatar
soundman
soundman is offline
I've done it on my Ultra with my girl on the back. Pulled the front wheel up at least 2 feet. It has Stage I with cams. After replacing my clutch with a barnett clutch, it really hooked up. Can really only pull a wheelie with my girl on the back, otherwise it just lights up the tire...which is cool too, except when its time for new tires.
Old 03-24-2010, 07:38 AM
FastHoss's Avatar
FastHoss
FastHoss is offline
My buddy had a neighbor that would pop up his Electra Glide at will,it's a skill.
Old 03-24-2010, 10:14 AM
Centerline's Avatar
Centerline
Centerline is offline
Watch out for that pooping Road King.
Like others said, if you got the skills, you can clutch up your bike, but you'll need some good traction under that back tire....won't do it on gravel.
I had a 30/70 sprocket set on my Dyna until last week (stock it was 32/66) the setup also shortened the wheelbase by 1" with the stock belt. My modded 103" motor would pull low power wheelies by blipping the gas in first....
short mini-wheelie video.....http://s260.photobucket.com/albums/i...rrent=2PW2.flv
Old 03-24-2010, 10:42 AM
kaynine840's Avatar
kaynine840
kaynine840 is offline
heres a link to a night train wheelie
http://www.youtube.com/watch?v=4Af5lwO9Vkw
Old 04-07-2010, 11:45 AM
Quadancer's Avatar
Quadancer
Quadancer is offline
I think you got that backwards...it's when your tire is worn out and you don't care to preserve it any longer that you abuse it!!!
OTOH, if you have spokes and abuse the rear wheel like that very often, you're either rich or an idiot. I do, however, regret not doing a big ol' burnout before replacing the back tire!!! Missed my opportunity!
Old 04-07-2010, 11:52 AM
cadman311's Avatar
cadman311
cadman311 is offline
If my tire has low tire prussure like around 9 pounds it will pull wheelie all day long and it gets hooked up. Just would not go out on the roads with low of tire pressure. I found this out went I was getting a flat.
wildbill71232
05-26-2014 01:32 PM
MCSarge
10-18-2009 04:28 AM
Sash302
07-04-2009 10:03 AM
handohd
EVO
05-20-2009 06:37 AM
Quick Reply: DOes this Train do Wheelies?
