Cam chain tensioners, no problem!!!
#94
#96
#98
I changed to an S&S setup with Andrews conversion cams which changes the chains to the 08, and up spec which are roller chains for the cams.
Good thought about chain roughness. Mine may look a little rough but it was smooth were it runs on tensioners. However anyone who polishes or sands on it should be vary careful to clean it up. Not sure if you could ever get the grinding dust from between the links.
MAY I ADD HERE THAT THE TIMING CHAIN IS UNLIKE THE ROLLER CHAIN IN THE PRIMARY. ONCE THE PRIMARY DRIVE CHAIN GETS DOWN TO THE CHAIN ROLLERS ON THE TENSIONER, THE TENSIONER THERE WILL PROBABLY NEVER WEAR OUT SINCE THE CHAIN IS ROLLING ON IT. NOT SURE WHY HARLEY DID NOT PUT A ROLLER CHAIN THE ON CAM SHAFT SPROKETS? I HAVE SEEN MUCH SMALLER ROLLER CHAINS
#99
What cams did you go with? Any comments?
Thanks
#100
On my 2000 EG I changed them and lifters at 52000 and they were about 1/2 worn. Put stock shoes back in and this set about 70,000.(120,000 on bike) I will be taking it apart around Christmas and probably putting stock shoes and lifters in. I know there will be no gear drive, maybe an oil pump
So what are TV he best lifters for stock build.
