Bike starts then stalls - no warning signs
Firstly, great site. Lots of good reading here. Looking for some help, so thanks in advance.
I have an 07 fxstsse with heavy breather, big radious, sert and calibrated by the dealer.
So, I started my bike today, sounded a bit different and blowing a bit of dark smoke and then it died. Started it again, and it died faster. Now it barely starts and dies within a second or two every time. I tried new plugs, new battery, gave all wires a little wiggle, checked and swapped some fuses...nothing. No symptoms prior to this either. Good thing I was home.
I ran and cleared the diagnostic codes, started it again, then checked the diagnostics codes again and here is what I get:
p0113
p0118
p0123
pn 176P 006-
Any ideas gang? Again, thanks for any assistance.
p0113
p0118
p0123
pn 176P 006-
RANKING DTC STATUS FAULT CONDITION SOLUTION
1 P0605 Current ECM flash error 4.29 DTC P0603, P0605
2 P0605 Historic ECM flash error 4.29 DTC P0603, P0605
3 P0603 Current ECM EEPROM error 4.29 DTC P0603, P0605
4 P0603 Historic ECM EEPROM error 4.29 DTC P0603, P0605
5 U1300 Current ECM serial data low 4.12 STARTS, THEN STALLS
6 U1301 Current ECM serial data open/high 4.12 STARTS, THEN STALLS
7 U1300 Current TSSM serial data low 4.12 STARTS, THEN STALLS
8 U1301 Current TSSM serial data open/high 4.12 STARTS, THEN STALLS
9 U1300 Current IM serial data low 4.12 STARTS, THEN STALLS
10 U1301 Current IM serial data open/high 4.12 STARTS, THEN STALLS
11 U1064 Current Loss of TSM/TSSM serial data-at ECM 4.32 DTC U1064, U1255
12 U1016 Current Loss of all ECM serial data-at TSSM 3.19 DTC U1016
13 U1096 Current Loss of IM serial data-at TSSM 3.20 DTC U1096, U1255
14 U1255 Current Missing response-at TSSM 4.32 DTC U1064, U1255
15 U1064 Current Loss of TSM/TSSM serial data-at IM 2.15 DTC U1064, U1255
16 U1016 Current Loss of all ECM serial data-at IM 2.14 DTC U1016
17 U1255 Current Missing response-at IM 4.33 DTC U1096, U1255
18 P1003 Current System relay contacts open 4.14 SYSTEM RELAY CHECK
19 P1002 Current System relay coil high/shorted 4.14 SYSTEM RELAY CHECK
20 P1001 Current System relay coil open/low 4.14 SYSTEM RELAY CHECK
21 P1004 Current System relay contacts closed 4.14 SYSTEM RELAY CHECK
22 P1009 Current Incorrect password 4.30 DTC P1 009, P1010
23 P1010 Current Missing password 4.30 DTC P1 009, P1010
24 P0373 Current CKP sensor intermittent 4.25 DTC P0373, P0374
25 P0374 Current CKP sensor synch error 4.25 DTC P0373, P0374
26 P0122 Current TP sensor open/low 4.23 DTC P0122, P0123
27 P0123 Current TP sensor high 4.23 DTC P01 22, P0123
28 P0107 Current MAP sensor open/low 4.20 DTC P01 07, P0108
29 P0108 Current MAP sensor high 4.20 DTC P01 07, P0108
30 P0117 Current ET sensor voltage low 4.22 DTC P01 17, P0118
31 P0118 Current ET sensor open/high 4.22 DTC P01 17, P0118
32 P0112 Current IAT sensor voltage low 4.21 DTCP0112, P0113
33 P0113 Current IAT sensor open/high 4.21 DTCP0112, P0113
34 P1351 Current Front ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
35 P1354 Current Rear ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
36 P1352 Current Front ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
37 P1355 Current Rear ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
38 P1357 Current Front cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
39 P1358 Current Rear cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
40 P0261 Current Front injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
41 P0263 Current Rear injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
42 P0262 Current Front injector high 4.24 DTC P0261, P0262, P0263, P0264
43 P0264 Current Rear injector high 4.24 DTC P0261 , P0262, P0263, P0264
44 P0562 Current Battery voltage low 4.28 DTC P0562, P0563
45 P0563 Current Battery voltage high 4.28 DTC P0562, P0563
46 P0501 Current VSS sensor low 4.27 DTC P0501 , P0502
47 P0502 Current VSS sensor high 4.27 DTC P0501 , P0502
48 P1651 Current Check engine light open/low 4.6 IM SELF DIAGNOSTICS
49 P1652 Current Check engine light high 4.6 IM SELF DIAGNOSTICS
50 P1653 Current Tachometer low 4.6 IM SELF DIAGNOSTICS
51 P1654 Current Tachometer high 4.6 IM SELF DIAGNOSTICS
52 P1356 Current Rear cylinder no combustion 4.19 COMBUSTION ABSENT/INTERMITTENT
53 P1353 Current Front cylinder no combustion 4.19 COMBUSTION ABSENT/INTERMITTENT
54 P0444 Current Purge control open/low 4.26 DTC P0444, P0445
55 P0445 Current Purge control high 4.26 DTC P0444, P0445
56 P1481 Current Fan output open/low 4.15 FAN OPERATION CHECK
57 P1482 Current Fan output high 4.15 FAN OPERATION CHECK
58 P0505 Current Loss of idle speed control 4.17 IDLE AIR CONTROL
59 B1135 Current Accelerometer fault 3.1 8 DTC B1 135
60 B1134 Current Starter output high 3.1 7 DTC B1 134
61 B1121 Current Left turn output fault 3.14 TURN SIGNAL ERRORS
62 B1122 Current Right turn output fault 3.14 TURN SIGNAL ERRORS
63 B0563 Current Battery voltage high 3.15DTCB0563
64 B1131 Current Alarm output low 3.16 DTC B1131.B1132
65 B1132 Current Alarm output high 3.16 DTC B1131.B1132
66 B1141 Current Ignition switch open/low 3.14 TURN SIGNAL ERRORS
67 B1003 Current IM internal fault 2. 10 DTC B1 003
68 B1004 Current Fuel sender low 2.11 DTCB1004/B1005
69 B1005 Current Fuel sender open/high 2.11 DTCB1004/B1005
70 B1006 Current Accessory line overvoltage 2.12DTCB1006/B1007
71 B1007 Current Ignition line overvoltage 2.12DTCB1006/B1007
72 B1008 Current Trip switch closed 2. 13 DTC B1 008
73 U1300 Historic ECM serial data low 4.12 STARTS, THEN STALLS
74 U1301 Historic ECM serial data open/high 4.12 STARTS, THEN STALLS
75 U1300 Historic TSSM serial data low 4.12 STARTS, THEN STALLS
76 U1301 Historic TSSM serial data open/high 4.12 STARTS, THEN STALLS
77 U1300 Historic IM serial data low 4.12 STARTS, THEN STALLS
78 U1301 Historic IM serial data open/high 4.12 STARTS, THEN STALLS
79 U1064 Historic Loss of TSM/TSSM serial data-at ECM 4.32 DTC U1064, U1255
80 U1016 Historic Loss of all ECM serial data-at TSSM 3.19 DTC U1016
81 U1096 Historic Loss of IM serial data-at TSSM 3.20 DTC U 1096, U1255
82 U1255 Historic Missing response-at TSSM 4.32 DTC U1064, U1255
83 U1064 Historic Loss of TSM/TSSM serial data-at IM 2.15 DTC U1064, U1255
84 U1016 Historic Loss of all ECM serial data-at IM 2.14 DTC U1016
85 U1255 Historic Missing response-at IM 4.33 DTC U1 096, U1 255
86 P1003 Historic System relay contacts open 4.14 SYSTEM RELAY CHECK
87 P1002 Historic System relay coil high/shorted 4.14 SYSTEM RELAY CHECK
88 P1001 Historic System relay coil open/low 4.14 SYSTEM RELAY CHECK
89 P1004 Historic System relay contacts closed 4.14 SYSTEM RELAY CHECK
90 P1009 Historic Incorrect password 4.30 DTC P1 009, P1010
91 P1010 Historic Missing password 4.30 DTC P1 009, P1 010
92 P0373 Historic CKP sensor intermittent 4.25 DTC P0373, P0374
93 P0374 Historic CKP sensor synch error 4.25 DTC P0373, P0374
94 P0122 Historic TP sensor open/low 4.23 DTC P01 22, P0123
95 P0123 Historic TP sensor high 4.23 DTC P01 22, P0123
96 P0107 Historic MAP sensor open/low 4.20 DTC P01 07, P0108
97 P0108 Historic MAP sensor high 4.20 DTC P01 07, P0108
98 P0117 Historic ET sensor voltage low 4.22 DTC P01 17, P0118
99 P0118 Historic ET sensor open/high 4.22 DTC P01 17, P0118
100 P0112 Historic IAT sensor voltage low 4.21 DTCP0112, P0113
101 P0113 Historic IAT sensor open/high 4.21 DTCP0112, P0113
102 P1351 Historic Front ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
103 P1354 Historic Rear ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
104 P1352 Historic Front ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
105 P1355 Historic Rear ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
106 P1357 Historic Front cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
107 P1358 Historic Rear cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
108 P0261 Historic Front injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
109 P0263 Historic Rear injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
110 P0262 Historic Front injector high 4.24 DTC P0261, P0262, P0263, P0264
111 P0264 Historic Rear injector high 4.24 DTC P0261, P0262, P0263, P0264
112 P0562 Historic Battery voltage low 4.28 DTC P0562, P0563
113 P0563 Historic Battery voltage high 4.28 DTC P0562, P0563
114 P0501 Historic VSS sensor low 4.27 DTC P0501 , P0502
115 P0502 Historic VSS sensor high 4.27 DTC P0501.P0502
116 P1651 Historic Check engine light open/low 4.6 IM SELF DIAGNOSTICS
117 P1652 Historic Check engine light high 4.6 IM SELF DIAGNOSTICS
118 P1653 Historic Tachometer low 4.6 IM SELF DIAGNOSTICS
119 P1654 Historic Tachometer high 4.6 IM SELF DIAGNOSTICS
120 P1356 Historic Rear cylinder no combustion 4.19 COMBUSTION ABSENT/INTERMITTENT
121 P1353 Historic Front cylinder no combustion 4.19 COMBUSTION ABSENT/INTERMITTENT
122 P0444 Historic Purge control open/low 4.26 DTC P0444, P0445
123 P0445 Historic Purge control high 4.26 DTC P0444, P0445
124 P1481 Historic Fan output open/low 4.15 FAN OPERATION CHECK
125 P1482 Historic Fan output high 4.15 FAN OPERATION CHECK
126 P0505 Historic Loss of idle speed control 4.1 7 IDLE AIR CONTROL
127 B1135 Historic Accelerometer fault 3.18 DTC B1 135
128 B1134 Historic Starter output high 3.1 7 DTC B1 134
129 B1121 Historic Left turn output fault 3.14 TURN SIGNAL ERRORS
130 B1122 Historic Right turn output fault 3.14 TURN SIGNAL ERRORS
131 B0563 Historic Battery voltage high 3.15DTCB0563
132 B1131 Historic Alarm output low 3.16 DTC B1131,B1132
133 B1132 Historic Alarm output high 3.16 DTC B1131, B1132
134 B1141 Historic Ignition switch open/low 3.14 TURN SIGNAL ERRORS
135 B1003 Historic IM internal fault 2. 10 DTC B1 003
136 B1004 Historic Fuel sender low 2.11 DTCB1004/B1005
137 B1005 Historic Fuel sender open/high 2.11 DTCB1004/B1005
138 B1006 Historic Accessory line overvoltage 2.12DTCB1006/B1007
139 B1007 Historic Ignition line overvoltage 2.12 DTC B1006/B1007
140 B1008 Historic Trip switch closed 2. 13 DTC B1 008 __________________
Harley002
09-26-2011 08:36 AM
