battery life expectancy?
Charge the battery on a tender until it is fully charged. Disconnect the charger for about 2 hours check battery with a volt meter. If it is 12.8 or higher it can be load tested and chances it is fine. If it is below 12.8 it is getting weak, will still last for quite awhile if you keep it charged. Of course if you have a load tester then you will know for sure.
Mine is three+.. expecting three more.
I ve read in here some lasting 7yrs, probably average 5-6 with normal use during summer riding couple times a week over 45minutes or so, and on tender in storage.
They do provide the service, but that test wouldn't tell you that the battery is low (unable to deliver the needed power) because of another component in the charging system failing. Best to test the battery with a full charge.
The one on my '02 Ultra is 8 years old, and still PLENTY strong! ...... I've never before had any battery, on anything, equal that!
just bought a new ODYSSEY battery from westcoast batteries for my FatBagger. the OE battery was getting a bit weak & the cool part about the new one is, it's an inch shorter than OE, & if you do add-ons it gives a bit more space under the seat for wiring or those bigass connectors, if your mod is plug-n-play
http://www.odysseybatteries.com/battery/pc545mj.htm
