battery life expectancy?
#51
Battery life is relative to ambient temp, charging system reliability, length of riding...listening to your radio while you clean it duh...your battery needs a good 30 minute ride at 2k-3k rpm to charge, a tender if fine but I don't recommend it solely, just starting once in a while does nothing but drain it...I recommend twisting that little star nut under the throttle and let it run at 2500 rpm for 20-30 minutes...if you can't get it out on the road...
I have a dead cell in my battery, have for 3 years but I have a good charging system and I ride a highway at least 30 minutes twice a week, with the carb problem I was having turning it over after a jet change long enough to refill the float bowl and test rides drained it more than once... but regular highway time charges it right back up...
