To Big Bore or not?
To Big Bore or not?
My local dealer is running a special on installing 1550cc Big Bore Stage II Kit with includes the SE 203 cams, or my choice, for my 2006 Road King Classic. When all is said and done it looks like it will run about $2,000 with tuning and tax. I had the Stage I upgrade done when I bought this Spring. My question for those of you who have done this is do you feel you got a good increase in performance for the money and did it have any impact on your gas mileage?
Thanks
Thanks
RE: To Big Bore or not?
2k is waay high, IM0. 203 cams are about 300 bucks. A set of SE flat top pistons are 129 bucks. A gasket set is about 75 bucks, and boring your existing jugs about 150 bucks. Then, I guess they will throw in a generic Stage II download for about 100 bucks. That comes to about $800 dollars for parts retail. (Rember the dealer likeyl pays way less than half for those parts). At any rate the other $1200 for labor is pretty steep, IMO.
All in all, you will likely gain 10-15 hp with a 203 cammed Big Bore kit over a good tuned Stage I providing you do no headwork when you do the Big Bore. You gas mileage will be about the same.
If $2000 is a special, I'd get another dealer.
$299 SE 95" cylinders (Bore yours $130 and better cylinders when done)
$129 SE Flat top pistons
$279 SE 203 cams
$90 Misc gaskets (estimated high side)
Does it include a SERT? Or is "tuning" just a download?
$469 SERT (retail over price)
$149 SE stage II Download
Are they Dyno tuning the bike? Most dealers aren't qualified to dyno tune IMO. Even so, Dyno tuning should come in at $350-$500. Dealers seem to think $100/hr and 8 hrs is what it takes to tune a bike.
Stuff they should do but probably won't.
Change the inner cam bearings to Torrington's
Change the tensioners shoes while it is apart
Change the lifters if mileage close to 30K
We do 95" big bore builds and they come in around $2500 but typically include SERT, Tuning, Torrington bearings, Bored stock cylinders, ported heads, cams, pistons, machine work to correct squish, chain tensioners, lifters, gaskets, cometic head gaskets and labor to install.
I'm not saying they are over charging but I would find out EXACTLY what they are doing for that money. Some dealers charge an hour to install a SERT. There is NOTHING to install. Buyer Beware is all I'm saying.
$279 SE 203 cams
I agree 100% with what Springer_ and the others have said.
Additioanlly, the 203 cam is "OK", at best. I do not know what bike you're considering installing this in, but there are several cams options that will give you much better results!
The special at $1828 (without tax or dyno tuning), includes a 29775-02B kit, adjustable pushrods, calibration which is a download, and labor. This kit includes a SE Air Cleaner and Breather Kit which I already have installed. So I do not need the Air Cleaner and Breather Kit nor the adjustable pushrods as I understand if I go with the standard SE 203 cams. Therefore a $810 kit and pushrods discounted a total of $276 dollars does not seem like good deal if it includes about $280 dollars of part I do not need. I already have the SERT and while they say it normally takes about 4 hours to tune on the dyno, they would only charge me for 2 hours. They are going to look into pricing only the parts I need rather than the on-sale kit and let me know the cost tomorrow.
Squish is the area between the flat of the piston and the flat of the cylinder head at top dead center (TDC). On the compression stroke, as the piston approaches TDC, the compressed mixture of fuel and air is "squished" to the remaining space of the combustion chamber where the spark plug and valves reside. The "squeezing" of the mixture creates turbulence and promotes a better and more complete combustion.
Doesn't sound like any kind of deal to me. My Stage II 95" kit was $850 plus $600 labor. Back in March. I also got the SERT instead of the download.
My fuel mileage actually went up. Best tank so far was 44mpg. Average around 38mpg and I run the **** out of it.
My Dealer had the gonads to tell me 2 hours to install the sert.
I told him if it takes his mechanics 2 hours to plug in two cables, and boot a computer, they need to be fired.
