S&S , Revtech or Jim's tappets ?
Old 11-09-2010, 10:16 PM
Bike-R-Mike's Avatar
Bike-R-Mike
Bike-R-Mike is offline
Default S&S , Revtech or Jim's tappets ?
Ok , so here I am again . I just did the inner cam bearing on my 95 Dyna not long ago and then I went and bought my Road King and now I need to do the cam bearing on it also . My question is , while I'm in there I might as well change the tappets too , right ? And if so , in order of best to worst , how would you rate S&S , Revtech and Jim's against eachother ?
Old 11-09-2010, 10:31 PM
arealinvestor's Avatar
arealinvestor
arealinvestor is offline
Try Wood performance he has some nice ones too!!
Old 11-10-2010, 12:16 AM
shovel13's Avatar
shovel13
shovel13 is offline
or maybe V-Thunder by Comp Cams. I've sure been satisfied with the lifters and blocks i bought a few years ago.
Old 11-10-2010, 07:01 AM
geargrinder's Avatar
geargrinder
geargrinder is offline
Unless you have over 100,000 mi or a .6 or higher lift cam, I would not worry about it. If your rollers show wear, your cam lobes probably do too so cam and lifters need replacing. But to more directly answer your question, price would be my deciding factor from any reputable supplier.
Old 11-10-2010, 07:53 AM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 13,750 Likes on 6,195 Posts
After 25000 miles on a new cam, etc., I didn't like the sound my stock lifters were making. When we took them out, you could wiggle the roller and needle bearings would drop out. You can bet we counted to make sure none had gone into the bottom end.
Replaced with Jim's big-axle hydraulics. Another 50000 miles and still performing well and also very quiet. Hope that helps.
Bikerscum
2014-2023 Touring Models
06-07-2015 09:53 PM
johnod
EVO
02-21-2015 11:17 PM
8828alex
01-29-2013 07:20 AM
Biker Bob
Exhaust System Topics
05-27-2011 09:02 AM
jarhead45
07-29-2009 10:19 PM
Quick Reply: S&S , Revtech or Jim's tappets ?
