Nitrogen in tires
Old 11-14-2010, 08:20 PM
asahi1234's Avatar
asahi1234
asahi1234 is offline
Default Nitrogen in tires
I am planning getting a 2011 Road king Classic. My question is you can put nitrogen in car and pickups can you do the same for motor cycles?
Old 11-14-2010, 08:23 PM
Kadorja's Avatar
Kadorja
Kadorja is offline
Harley has a nitro fill service you can get with your bike.
Old 11-14-2010, 08:24 PM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
why not ?
IMO its a waste of money though.
Old 11-14-2010, 08:28 PM
Kadorja's Avatar
Kadorja
Kadorja is offline
Originally Posted by FroggyFatBoy
why not ?
Apparently its dryer than regular air so the tires last longer... something like that. I think it was like $50 or something when I bought the bike. If it keeps my tires lasting a couple hundred miles longer than I'd say its worth it but who knows.
Old 11-14-2010, 08:32 PM
artz's Avatar
artz
artz is offline
I think the only way to keep your tires lasting longer is to don't put the miles on'em.
Old 11-14-2010, 08:34 PM
FroggyFatBoy
true, nitrogen has no moisture. the benifit is supposed to be you have no erratic pressure change in the tire, mainly excessive pressure rise due to heat build up. the thing for nitrogen to work correctly and be a benifit, the tire assy must be pumped down like a ac system to remove all moisture and never use regular compressed air to top off the tire if it does get low. as for making a tire last longer due to no moisture, i haven't heard that one.
that being said, its great for race vehicles in tires and shocks because the pressure won't build and it makes for a more consistent handling of the vehicle.
Old 11-14-2010, 08:35 PM
FroggyFatBoy
or jack it up to put a few hundred miles on it.. kinda like Chong in Up in Smoke..
SeeMeDo's Avatar
SeeMeDo
SeeMeDo is offline
It's a gimmick air is 78% nitrogen if you where racing then it would be worth it since nitrogen stays pretty constant and doesn't expand. If you check your tires once a week unless you are loosing air it's a waist but it helps keep people earning money.
Old 11-14-2010, 08:38 PM
Gruamach's Avatar
Gruamach
Gruamach is offline
Any air-filled tire can be filled with nitrogen.
But as has been said: The Cost to Gains ratio = "Pointless gimmick"
Old 11-14-2010, 08:40 PM
CRASH69's Avatar
CRASH69
CRASH69 is offline
Harley in Palm Beach Florida has Nitrogen on there Display bikes, They put green caps on them, The problem with air is when add to your tires it gets some water from the air compressors not having proper filtration, My freind does tires at his shop and you can see the old tires are wet inside and it rots the rubber, I have good filtration on my own compressor and I still cant keep the water out, The nitrogen comes clean in big tanks that look like the welding tanks...Crash
Quick Reply: Nitrogen in tires
