2008 road king starter relay
I have a 2008 RKC, I was reading thru the service manual, and found the fuse panel diagram, it showed the starter relay to be located on the panel part number 31579-04, it is a small four prong unit. I wanted to have a spare, so I went to the Stealer, and asked for a starer relay for my RKC, he looked it up and gave me a 31579-91b, a 5 prong unit. I cannot find any mention of this part in my service manual. Does anyone know which is the right unit? Thanks.
Did a quick search on google...
Found this PDF file... http://www.digitalguarddawg.com/PDFS...tion-Guide.pdf
It only goes up to 2007, but if you scroll down just a little in the 'Touring 1998-2007' section, you will come to a yellow box just under the images. It states...
Replaces H-D Relay part# 31579-04
Perhaps your '08 is the same? I would've thought the parts guy/gal would have mentioned it to you if it had?
The two numbers after the dash indicate the revision number, and that usually coinsides with the year the revision came out...
Looking at these two part numbers, it would seem they replaced a new part with an old one. Guess sometimes newer aint better!
***2004 - 2007 FLHR series bikes &
2007 FLHX require additional Adaptor
AD-1 & DGD-1. Start Relay is in Power
Distribution box.
Distribution box.
2013_FLHTK
12-12-2013 05:18 AM
fxstbharley2008
02-01-2008 04:34 PM
