lugging the engine?
Old 12-16-2010, 10:28 PM
asahi1234's Avatar
asahi1234
asahi1234 is offline
Default lugging the engine?
I know most will say this is a stupid question but what is lugging the engine mean? Thanks for your reply's.
Old 12-16-2010, 10:33 PM
Centerline's Avatar
Centerline
Centerline is offline
Operating the bike in too HIGH of a gear, causing TOO low engine RPM's for the speed or the load being put on the engine ..... say maybe climbing a steep grade in too high a gear. You can feel a shudder thruout the bike of heavy. low frequency vibes as the engine struggles thru each stroke. Easier probably to experience "detonation" or knock when lugging the engine.
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,540 Likes on 3,792 Posts
Default Lug
Running it it too high a gear range. Like trying to do 20 in 4th gear
Old 12-16-2010, 10:34 PM
Mr Haus's Avatar
Mr Haus
Mr Haus is offline
I thought it was when you are going too slow for the gear you are in... and you rev it back up to speed... you know that chugging lugging that happens until you get the proper speed.
I might be wrong.
Old 12-16-2010, 10:36 PM
asahi1234's Avatar
asahi1234
Thanks for the info as you can see I am new and learning.
Old 12-16-2010, 10:37 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
Mate the only stupid question is the one that isn't asked......
Centerline and Grf000 provided the answer. I'll just say it's not a good thing to do and you will know it when it happens.
Old 12-16-2010, 10:39 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
I might be wrong.
That's a good way to put it as well....
Old 12-16-2010, 10:40 PM
BassCatcher's Avatar
BassCatcher
BassCatcher is offline
I'm fairly certain anyone with experience driving a stick shift (car or motorcycle) would have to be familiar with the dangers of over lugging your engine. But I will tell you what, most of these young kids raised driving only an automatic would have no clue what you are talking about.
Kind of sad really.
Old 12-16-2010, 10:45 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
It's the noise the tractor makes when you try to start off in fifth gear with 18 feet of cultivator planted.
Old 12-17-2010, 07:53 AM
oct1949's Avatar
oct1949
oct1949 is offline
Generally I like to stay 2k or more in 4th, 5th and 6th..
some built motors I read have to keep it higher to prevent spark knocking.
Quick Reply: lugging the engine?
