2nd Main Shaft Bearing Failure Update
Posted earlier about bringing in my '08 Dyna for the 2nd
main shaft bearing failure in 37,000 miles. First at 24,000.
The dealer told me some crap yesterday about how a field rep
had to come inspect the parts and decide whether to
honor the extended warranty that I had paid dearly for. I went
in this morning with both barrels loaded, but waited to see what
the rep would say over the phone. Long story short is they
will cover entire repair-north of $650.00 with parts and labor as the
trans got torn up again. No warning other than small oil drip, but
the tech said when he first rode it he heard the telltale sound, which
he apparently has quite a bit of experience with this particular bearing failure (he's done at least 6 in the last month). Thank God
I purchased the warranty, but I wonder how many times HD is going
to want to fix the same problem again and again. I've got 4 more
years on this warranty, so I guess they want to eat it about 3 more times. You would think they might learn from such a common and
expensive shortcoming in the bearing quality/design issue. I love my bike, but this was too much the first time. Also had 2 rear wheel bearings fail under warranty, but had to purchase a $500.00
rim as the race had spun in the hub. I'm not stupid enough to keep riding a bike with a condition that I can tell is not right, but these bearings give little to no warning. WAKE UP HD! Sorry for the long rant, but had to get it off my chest. My bike is one of the most important things that I have been blessed with, and it's frustrating when HD makes mistakes into some big mystery that they are too afraid to admit to, fix it, and move on.
I agree with you, they should man up and not only repair , but install upgrades to prevent future failures. In my mind they should have paid for the wheel too! Their bad part caused the damage!!
My son has 25K on his 06 Street Bob without a single issue. He's 6'5" and 270. He's went up the Alaskan Highway and to Key West. He has covered much of the U.S. with it.
He does not baby it at all and does all of his own services. He is an ASE cert. master mechanic and has a service manual. He goes through the bike each winter.
Could it be more how a bike is maintained and less who made it? Just wondering.
Here's a picture of the Dyna between my Buell and his brother's BMW. Those are large ammo cans with two one gallon gas cans on the back. He also had a duffel bag that went across the improvised saddle bags. The location was Butte Montana on our way to the Arctic Circle last year.
Extended warranty is an insurance policy really. I am not aware if Harley is actually behind this or if Harley farms it out to an independent company. Regardless, to protect their name Harley should certainly take care of this issue with a recall if needed. Should some one get seriously hurt or God forbid killed due to a wheel falling off, there will be one heck of a field day at the local lawyers office.
go with the baker bearing bud will be a GREAT upgrade mine was a mess when i did mine as well
when chad and i did mine it was impacted on and had to be tack welded to be pulled off
crap bearings
crap bearings
mainshaft/primary bearing
i wrote way back about trouble with both these bearings. there are so many people here than think they know what the problem is with both bearing. "till u have experienced and got thru bullcrap with HD then u really know what's up with it. HD just gives all the bullshit story, unless u have extended warranty. HD dosen't give a rats *** about your trouble, knowing they know there is big problem with both bearing.. i wrote in this fourm way back and explained issues as to what to look for. as to the failure of mainshaft bearing i'm still at wits as to why they fail.. the primary bearing it's explained why. i even connect *** bearing corp. that makes mainshaft bearing for HD . they don't give a crap either. so to sevice my memory right, look up in this forums search 6 speed transmission failure or mainshaft failure. or something like. it explains what i personally had repaired 4 harley mainshaft bearing on 4 different bikes all 6 speed and the failure of bearing wear pattern are all the same.. if u read that one u found right article.
