Best Motor Oil
Old 02-05-2011, 01:58 PM
NavyCharles24's Avatar
NavyCharles24
NavyCharles24 is offline
Location: Longwood, Florida, Seminole County, United States of America
The argument about WHICH BRAND of Oil is the best is so subjective it's annoying to repeat.
I read an Article, in the summer, that ranked Royal Purple as one of the lowest.
This is my belief....
I will choose Synthetic Oil over Dinosaur Oil.
I generally use Mobil 1 Oil, as I have for decades, but if a competitor is on Sale, I will switch.
I stay with Top Tier Synethic Oil versus the crapshoot oil you may find in the discounted stores or flea markets.
I will choose a great Oil Filter because that is a huge part of the Oil Cooling and Cleansing system.
Royal Purple vs Amsoil vs. Mobil vs. Red Line...blah blah blah.
I'm sick of it.......
See ya on the road....
Originally Posted by CobraEd
Check out this article. Most all of the oils test out the same until you scroll all the way down to the bottom of the list. I knew that Royal Purple oil was terriffic stuff from other info I have read, but look at the results here. Huge difference!!! They make a 20 - 50 motorcycle oil that is all I use in my Dyna.
http://www.animegame.com/cars/Oil%20Tests.pdf
Old 02-05-2011, 01:59 PM
Hollywood Ball's Avatar
Hollywood Ball
Hollywood Ball is offline
I use Kaluah. And drink it when it's changed out.
Old 02-05-2011, 02:02 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
Do you remember the article? It would be helpful.
Old 02-05-2011, 02:03 PM
schumacher's Avatar
schumacher
schumacher is offline
Old 02-05-2011, 02:07 PM
streeteagle's Avatar
streeteagle
streeteagle is offline
I did'nt see Amsoil in this test, a glaring omission IMO.
Old 02-05-2011, 02:20 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Well, here's the updated Amsoil white paper, on 40 weight and 50 weight motorcycle specific oil. Royal Purple was last in the wear category on both weights.
http://www.amsoil.com/lit/g2156.pdf
Old 02-05-2011, 02:21 PM
Mal74's Avatar
Mal74
Mal74 is offline
Amsoil is what I use, but it's my personal preference.
Anyway...oh hell ... here we go again!!!!!!!!!!!!!!!!
Old 02-05-2011, 02:51 PM
barjbar's Avatar
barjbar
barjbar is offline
I agree the test is procedure is flawed. The tests I've seen, where they use an oil in an engine over a very long period of time and then disassemble it & inspect it for wear is far superior. Those tests pretty much showed any quality oil works fine.
Old 02-05-2011, 02:53 PM
Turbo Flux's Avatar
Turbo Flux
Turbo Flux is offline
No one ever talks about what these ultra-slicks do long term use on piston rings (oil consumption). Rings require a certain amount of friction to work properly.
Old 02-05-2011, 03:08 PM
teflon's Avatar
teflon
teflon is offline
Tests are very specific, way to many variables unless you exactly the specific useage and oils. I will say this, we used RP twice in our stock cars and gave the rest away, just would not hold its viscosity. Mobile 1, Brad Penn our the"special" Castrol is our choice for automotive type engines. Amsoil in the bikes if you wanna do all three holes is good with that oil, the Mobile 1 is good in the bikes as well. Ralph
Quick Reply: Best Motor Oil
