V&H True Duals VS High Output Pro Pipe
Check out this dyno sheet with a 2-into-1 Thunder Header and MGS True Duals. Power curve is better in our opinion with the True Duals. What do you think?
Impossible. Unless you are now running in a higher gear than you were before. Simply impossible.
Glad someone else caught that, But I think I figured it out. He wasn't getting into 6th gear before. Either that or the fuel pak tweeked his speedo. Don't matter whether you're 1 up, 2 up or 4 up, RPM vs speed is straight simple math and it can't change without changing gears, pulleys or tire size.
Kretzmar (02-17-2017)
What will change with more power is the position of the throttle, a engine with more power will take less throttle to do the same speed. RPM will continue to be the same for a given mph no matter how much power you have.
How did I miss this thread? Maybe after he changed pipes, he was going in the same direction as the wind and therefore needed less RPMs to go the same speed.
I have a standard Pro Pipe Chrome that I put a quiet baffle into because the standard baffle was too loud for long trips. Didn't like the sound of the quiet baffle so I wrapped both sections of the standard baffle with muffler packing and got the perfect combination of sound and loudness.
rlydan
04-30-2010 04:56 PM
