Bolt broken in Lower Rocker
Hello HD forum veterans,
My name is Charlie. Im from Indianapolis and I ride a 2008 Nightster.
Just recently I took on the task of removing my rocker boxes to replace the gaskets. While doing so I broke a bolt off inside on the lower rocker box. I purchased a screw extractor. Could I have some veteran advice before I undertake this operation.
Also, I tried to keep the project moving by working on the (front cyclinder) lower rocker box. And for some reason I can't get it to sit flush. The push rods are holding the lower rocker from sitting properly by about a 1/4inch all around. I've been rotating the rear tire with the bike in 5th gear.
Thoughts and suggestions appreciated!
Received 4,317 Likes
You have to tighten the bolts a little bit each before going on to another bolt.. They will gradually compress the lifters and the rocker boxes will go flush. If you try to tighten them too fast you will bend your pushrods.
You don't have to rotate the tire at all.
Can you lift the lower rocker box off and grab the head of the bolt with some vice grips?
Texashillcountry- Unfortunately, when the bolt broke, the head of bolt came off (in my hand now) while the remainder stayed in the threads. Thus, the broken bolt is essentially holding the lower rocker to the top of the engine. I purchased a screw extractor and I'd love to have some expert advice before I attempt to use it.
In addition, I purchased a new lower rocker (Yes- I am assuming that i mess up the threads in the current lower rocker). Is there anything special about swaping the camshaft arms from one lower rocker to the next?
Thank you for your help and advice!
Douglas C Trowbridge
Engine Mechanical Topics
08-28-2015 04:02 PM
hitman1267
05-20-2014 02:55 AM
