Cam chain tensioner problems with an 88
Old 04-09-2012, 08:26 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
Well, I just bought a 88 ci softail and will need to follow this thread to see more about this issue.
  #42
Old 04-09-2012, 09:53 AM
05RKCRider's Avatar
05RKCRider
05RKCRider is offline
It's the fu*+ed up `silent' chain that cuts thru the shoes like a knife that is the problem. Notice the `new' chain is a roller type with hydro tensioner but shoes are same material. I went with gear drives at 1,000 miles & shoes had about 1/16" wear on them. Money well spent.
  #43
Old 04-09-2012, 01:08 PM
Kyle VanLeuven's Avatar
Kyle VanLeuven
Kyle VanLeuven is offline
Stage I
Default cam chain tensioner
Well I had an interesting problem with my tensioner, not the shoes wearing out, but the spring snapped and the tensioner rotated backwards. it was just simply flopping around out of the way not holding up against the chain. doesnt appear to be any damage and shoe is well... new so just need to find a spring. I am not sure if they sell the spring on its own or needs the whole damn tensioner rebought. Additionally has anyone found a way around the special socket used to take the spring tension back during installation?
  #44
Old 04-13-2012, 07:15 PM
NAILIT RK's Avatar
NAILIT RK
NAILIT RK is offline
Originally Posted by magna
Anyone upgrading to the hydraulic tensioner kit had better visit the Softail forum and read the post there about them.
Thanks Magna, caught me just in time as the HD kit and cams were ordered, no longer, going with Andrews rollers now...
  #45
Old 04-13-2012, 07:48 PM
strongwood's Avatar
strongwood
strongwood is offline
I just replaced my shoes and I think I still have the old ones if you want the spring
You have to buy the whole tensioner for 70 bucks
You don't need the tool to remove the spring, a good pair of channel locks and a small drill bit for the pin will work
Watch this video, fast forward to about 5:40
A word of caution, you will have to take off the outer gears, install the tensioner and pin it back then re install the gears.
10 minute job!
http://youtu.be/0WY8KbPBnYU
Let me know and I will look to see if i threw them away or not
Daddie O
08-17-2015 08:07 AM
ekim189
06-23-2015 06:47 PM
VINNIE JAMES
03-25-2013 02:27 PM
gsparesa
03-24-2007 07:28 PM
huffhuff
06-15-2006 06:25 PM
Quick Reply: Cam chain tensioner problems with an 88
