nail in my tire (sideways in the tread)
when I was messin with the bike last night, found a nail sticking out of the tread sideways.....frikkin yay. pulled it, did the soap test, and it luckily didn't go through. might start looking for another tire though, gonna keep an eye on it
I've had short nails in truck tires like that before. Never caused a leak. Hope yo're good, but if not being it's a cast wheel maybe you could do a plug and patch if need be til you can get a new tire,
No worries
That happened with my '07 Sportster about two months after I got it. I pulled it out and rode it.
I got 13 thousand miles out of that tire!! It's a real pisser you can't get the same tires that they put on them from the factory.
If you are certain the nail didn't penetrate the cord, but instead only went into the outer tread rubber, you'll be OK. Otherwise I'd replace it w/ a Metzler. How many miles on it?
Edit to add that you should adjust your budget to include roadside hazards such as this. Be safe.
I have removed nails before that didn't go all the way into the cord and finished out the life of the tire. I would just watch it. I wouldn't replace it with a damn Metzler. Getting rid of the second and last set of them I ever run on one of my Harley's soon. Going to Avon's next on the Wideglide and I am leaving Dunlops on the Heritage classic.
Last October I pulled out a 3/8-inch sliver of alumium from my rear tire...It never went flat and is still in use today! Keep a close eye on tire pressure and if it stays inflated for over a week you should be in the clear.
http://www.chaparral-racing.com/
