Hydraulic lifter/tappet noise
Old 05-25-2012, 11:48 AM
Big Trev's Avatar
Big Trev
Big Trev is offline
Default Hydraulic lifter/tappet noise
What part fails in a hydraulic lifter/tappet to make the clatter/noise?
Old 05-25-2012, 01:08 PM
blackbear's Avatar
blackbear
blackbear is offline
either loose push rods if there adjustible or the roller bearings in the lifter have fallen out or the lifters have some junk in them and there not pumping up
Old 05-25-2012, 04:47 PM
Big Trev's Avatar
Big Trev
Big Trev is offline
Cheers blackbear.
Still using the standard push rods,and the the roller bearings are good,we've washed them out,and now putting it back together so it remains to be seen if it'll cure the racket.
Old 05-25-2012, 04:54 PM
HD7585's Avatar
HD7585
HD7585 is offline
If you have a screen in your oil pump......clean it. About 30,000 miles ago my lifters started to make a racket. Cleaned the screen ,new oil and filter and it never happened again, just say'n
Old 05-25-2012, 08:15 PM
1Canuck's Avatar
1Canuck
1Canuck is offline
Received 2,252 Likes on 1,439 Posts
for me tappets are noisey when the oil has air mixed in, foam, bubbles on dipstick or when oil gets hot & thin. changed oil, installed Baisley spring and it sounds good overall, no more metal tapping sound
BigGelvis's Avatar
BigGelvis
BigGelvis is offline
What bike do you have, Year, Model?
I have checked with a decibel meter and I am getting 77 decibels at the engine near the cams on a 2012 103"
The 103" is a loud clattering motor! Drives me crazy but I got use to it.
Old 05-25-2012, 09:30 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,704 Likes on 1,989 Posts
One more thing to check. A minor exhaust leak at the cylinder head can make a noise much like a noisy lifter. I know this from experience. Check your exhaust flange nuts for correct torque, especially if you've changed your pipes. The gaskets tend to settle over time and small leaks can develop.
Old 05-26-2012, 04:05 AM
Big Trev's Avatar
Big Trev
Big Trev is offline
Cheers people, I'll check out some of the suggestions, it's a mates bike and had the SE cam plate upgrade done 1200 miles ago,then recently a tappet noise started ones more prominent than the others.
Old 05-30-2012, 04:16 PM
Big Trev's Avatar
Big Trev
Big Trev is offline
Update.
new lifters fitted and things are all quiet again,but would sure like to know what was wrong with the old set.
Starman321
Engine Mechanical Topics
08-13-2014 05:46 AM
JONNIEROCK
12-30-2013 06:35 PM
twist1
10-25-2013 09:18 AM
97classic
EVO
07-14-2009 02:17 PM
jjb
06-13-2009 06:59 AM
Quick Reply: Hydraulic lifter/tappet noise
