Drain plug o-ring popped off!
I just changed the oil on my dyna. The oil filter I bought (drag specialties) did not include an o-ring for the drain bolt. When I drained the oil, the current o-ring broke in half. So I went to my local autozone and bought a variety pack incluing one that fits. After having added the new oil, I decided to check if any oil was leaking from the drain plug. I then noticed the o-ring was flared and extending outside of the bolt. Now, I didn't go crazy over tightening it, but I did give it an adequate firmness. I thought to myself... might as well leave it as it is. When I wiped the area with a rag, the o-ring popped off! Now I have fresh oil, a tightened drain plug, and no o-ring. My instant reaction was to tighten the drain plug a little more. Has anyone rode without a drain plug o-ring? Will any oil leak from this? If so, is there any application i can put around the bolt that will create a temporary seal? Thanks in advance.
I don't think the plug is tapered like a pipe plug, so it will likely leak if you didn't use a thread sealer.A bolt with a matching thread and a quick hand would work while you put the right o-ring on the plug, then put it back in.
Mark
Mark
Ha Ha thanks, If you squirted the o-ring out it was likely to big. I buy my oil and filters at my local indy shop and he always hands me a couple free o-rings with my receipt. Figure out the rite o-ring and buy a hand full of em.
Do not ride without the O ring. Engine cost thousands, so replace it and lesson learned. Harley will give me o rings for the asking.
