Shovelhead or Ironhead
Old 07-14-2012, 04:05 PM
Nor Cal Mafia's Avatar
Nor Cal Mafia
Nor Cal Mafia is offline
Default Shovelhead or Ironhead
Whats the difference..Is it only called an ironhead when they put a shovelhead in a sportster?
Old 07-14-2012, 04:17 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,704 Likes on 1,989 Posts
In short, yes. Shovelhead big twins have aluminum cylinder heads. Older Sportsters (1957-1985), despite having rocker boxes which resemble the Shovelhead had cylinder heads made of cast iron, instead of aluminum, hence the term, "ironhead" for a Sportster.
Old 07-14-2012, 04:19 PM
bjewell's Avatar
bjewell
bjewell is offline
Iron heads usually refer to Sportsters made before the aluminum engines. Shovelheads usually refer to some of the coolest Harleys ever made...
Old 07-14-2012, 09:12 PM
Nor Cal Mafia
So the heads are different but rocker boxes the same?How bout the jugs etc?
Old 07-14-2012, 10:14 PM
bjewell's Avatar
bjewell
bjewell is offline
Dude, an ironhead is a Sportster. A Shovelhead is a big bike. Finito...
Old 07-14-2012, 10:21 PM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
Nope, the rocker boxes only look the same. They are completely different engines. Sportster is a "unit" - engine & tranny share the same cases. Shovel, and all the other Big Twin iterations, have separate engine and tranny cases.
Sporties have 4 cams; note that the pushrods are parallel. Shovels have 1 cam; note that the pushrods come off the cases at various angles, and are not parallel to each other. Ironheads all have generators, while '66 - '69 Shovels used generators; '70 up used alternators. '57 thru '71 Sportsters were called 900, though the engine was actually 883cc; '72 and later Ironheads were called 1000, though the displacement was 997.5cc.
Old 07-14-2012, 10:31 PM
mmcbeat's Avatar
mmcbeat
mmcbeat is offline
And the new Sportys are still Evos. Right?
Old 07-14-2012, 10:53 PM
pococj's Avatar
pococj
pococj is offline
Evo Sporties as opposed to Evo Big Twin. Most times when someone talks about an Evo they are referring to the BT model.
Old 07-14-2012, 10:57 PM
j1mmy's Avatar
j1mmy
j1mmy is offline
when they made the shovelhead, they copyed the ironhead,sportster head design,but the two have nothing in common besides looking kind of similar. sportster evo rocker boxes are different then the bigtwin, but are interchangeable if you wanted to.(i had a buddy that used sportster boxes just for the look on a softail chopper)..
any one know if the newer rubbermounted sportys are still considered evo?
Old 07-15-2012, 12:19 AM
Mickey D's Avatar
Mickey D
Mickey D is offline
Back in the day before 1985, all Sportster heads were cast iron . FYI, they were never refered to as Iron Heads prior to the Evolution design.
Though the rocker boxes looked similar, the Sportster has a notched rocker box look.
1973 Sportster
Quick Reply: Shovelhead or Ironhead
