Twin Cam tensioner failure
Old 11-08-2012, 02:42 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,572 Likes on 4,609 Posts
this thread doesn't even show up in my recent topics!!!
Old 11-08-2012, 04:01 PM
AtkRWC's Avatar
AtkRWC
AtkRWC is offline
Internet rumor! ;-)
Old 11-08-2012, 04:45 PM
Big Trev's Avatar
Big Trev
Big Trev is offline
Originally Posted by 2AMGuy
Many people are unaware of this potential problem.
Can't imagine how,cause the topic's nearly as popular as what's the best oil
Old 11-08-2012, 05:45 PM
skootchnc's Avatar
skootchnc
skootchnc is offline
as they say at the dealership..... "they all do that"... (well the TC-88)
Old 11-08-2012, 07:17 PM
73oldsman's Avatar
73oldsman
73oldsman is offline
Originally Posted by BornAgainWheels
I myself opted for the Gear Drive upgrade which seems to be the cheaper of the two option. The engine sounds a bit "clunkier" but at least now i got peace of mind. Its an inevitable issue with the twin cam. Hope this helps.
Gear drive maybe the best option, in the long run, but may not be the cheaper. It may not be an option at all if your engine doesn't "mike" within allowable limits to use a gear drive set-up. I inspected my tensioners and found the outboard one worn and cracked and decided to replace both tensioners. I also had to replace my inner cam bearings, as they were sub-standard, and identified during the 2000 HD production year. Some got changed, and some weren't. Mine wasn't. There are 3 options I know of, depending on your year of HD and motor. Stay with the original tensioners, upgrade to the new style hydraulic tensioner set-up, or go with the gear drive set-up. Hit the search button and start reading. Lot of info there....
Old 11-08-2012, 07:21 PM
2kids3pets's Avatar
2kids3pets
2kids3pets is offline
First time I've heard about this.......TODAY
Old 11-08-2012, 07:28 PM
Bones77's Avatar
Bones77
Bones77 is offline
Had to laugh to myself. Noticed I hadn't posted since July. I can see HDF hasn't changed. The peanut gallery is still alive and well. They might even have something useful to offer.
So, my sincere apologies. Sorry I was at work and didn't have time to do a thorough research of the archives. My bad. Thought some might be interested in the JP Cycle blog. I was off base there. Hey, I realize now it was only a technical blog about a Harley engine. No importance here.
Seems there's mixed results. For some not an issues. For others major $$. I know, even though I've a 2009, I'll be asking the mechanic to inspect every 15,000 miles.
Peace,
Bones
Old 11-08-2012, 08:04 PM
truckerdave's Avatar
truckerdave
truckerdave is offline
senior experienced all-knowing leader of the unwise
Originally Posted by soft 02
I have a 07. A non issue for me...
Yep, you're right. You only have to worry about the compensator failing and excessive pinion shaft runout taking out the oil pump. LOL
Old 11-08-2012, 08:24 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
All delt with. Comp self destructed at 40k. Se installed. One peice IPB, r&r tensioners at 90k, runout at. 003 no worries. 115 k and running strong.
Old 11-08-2012, 08:36 PM
omaho5's Avatar
omaho5
omaho5 is offline
Cam chain tensioner...Got mine from Fredricks of Hollywood.
Actually replaced mine on my Road Glide at 20,000. mi.
I do not beat on my bikes. Was not worn to a point of failure.
However I was putting in a 203 cam, so did tensioner.
Quick Reply: Twin Cam tensioner failure
