Vinyl wrap on upper fork tubes
Old 12-17-2012, 01:43 PM
SLV's Avatar
SLV
SLV is offline
Default Vinyl wrap on upper fork tubes
An experiment, but it looks good and holds up. I wrapped the upper fork tubes with #M 1080 Vinyl Car Wrap.
http://www.amazon.com/gp/product/B007856N1K/ref=oh_details_o05_s00_i00 http://www.amazon.com/gp/product/B007856N1K/ref=oh_details_o05_s00_i00
It took 10 minutes. Admittedly, I didn't do a very good job the first time around. I'll redo it over the holiday.
Someone with some skills could use just one sheet, cut it perfectly and get it on straight.
I cheated by applying a 1" strip at each end, then wrapping another sheet across the remaining section (with some overlap.)
If you look close, you can see the overlaps and a small wrinkle. From 10' away, or running down the road, it looks as though the tubes are black.
Old 12-17-2012, 01:58 PM
CB024's Avatar
CB024
CB024 is offline
I dig it! Good idea. I might have to try this. I still need to get my trees and lower forks done though.
Old 12-17-2012, 02:00 PM
SLV's Avatar
SLV
SLV is offline
I'm going with fork boots on the lower section of the tubes. I'll probably wait until the 1000 mile service though.
Old 12-17-2012, 02:02 PM
CB024's Avatar
CB024
CB024 is offline
Look forward to seeing the completed front end man. I think its going to look really slick.
Old 12-17-2012, 07:47 PM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Nothing wrong with the job you did. You did it yourself and it looks great. Nice Mod.
Old 12-18-2012, 10:50 AM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
Looks great.
Just wondering how easy those tubes will slide through the t-clamps when it comes time to install those gators. Might be a bit of a task with that vinyl tape on 'em.
Guess you can always pull the stuff off and replace it.
Old 12-18-2012, 12:33 PM
SLV's Avatar
SLV
SLV is offline
Originally Posted by Leftcoaster
Looks great.
Yeah. It peels right off and doesn't leave anything behind.
Old 12-19-2012, 02:10 AM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
good idea, nice mod
Old 12-19-2012, 08:15 AM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,630 Likes on 4,624 Posts
great idea, looks good!
Joboo1966
03-11-2014 01:00 PM
Robtarra39
02-08-2013 01:18 AM
mreed
08-25-2010 09:48 AM
'05Train
08-09-2010 11:31 PM
sdroadglide
07-28-2008 11:29 AM
Quick Reply: Vinyl wrap on upper fork tubes
