cannot decide between carb or EFI
Old 06-01-2013, 09:25 AM
97Hogcity's Avatar
97Hogcity
97Hogcity is offline
2nd Gear
Default cannot decide between carb or EFI
I have stock EFI on my 97 roadking but am rebuilding motor with a big cam and high compression pistons and port and polish. i have heard that EFI is hard to tune with new cam. plus i also heard that i might have to run a gas additive. I do like the thought of being able to work on carb. THOUGHTS!!!!
Old 06-01-2013, 09:28 AM
deano360's Avatar
deano360
deano360 is offline
i myself, i like to be able to work on my own bikr as far as tuning goes.... but i do like the power of the EFI.... at least with the carb. you can tune it yourself and get it the way you want it
Old 06-01-2013, 09:39 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
The older style EFI was harder to tune. The more modern system is very easy. There are even tuners that learn your performance needs as you go and make adjustments to the tune fit your bike. I really like EFI and how dependable and easy it is. That being said, on an older bike if you are going for performance, use a carb.
Old 06-01-2013, 09:41 AM
seph10's Avatar
seph10
seph10 is offline
carbs are great to work on,,efi set up right,,,you don't have to,,I would build the bike and go with efi, get it set up for what you built and forget it and ride,,,
Old 06-01-2013, 09:45 AM
Heritage10508's Avatar
Heritage10508
Heritage10508 is offline
Agreed^^
WG2011's Avatar
WG2011
WG2011 is offline
Only advantage to carb is the potato potato sound other than than efi ifs superior.
Old 06-01-2013, 09:56 AM
Beav's Avatar
Beav
Beav is offline
UNLESS you covert to Delfi, CARB all the way.
Been there, done that with MM. No aftermarket support. They are fine with millions of miles... in stock config. Once you start the mods...the headache's COMPOUND!
Your choice, but I'll not own another MM efi bike.
Old 06-01-2013, 10:15 AM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
EFI for me. Carbs are a thing of the past to me.
Old 06-01-2013, 11:12 AM
Jake911's Avatar
Jake911
Jake911 is offline
Modern EFI is nice. You have a 16 year old version and wiring. If it were me, I'd go with the carb or upgrade to a modern EFI system to go the next 16 years.
Carbs just look cool too.
Old 06-01-2013, 02:05 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,282 Likes on 2,349 Posts
The modern Delphi EFI is pretty reliable and easy to tune. The EFI from (( could/would present some tune problems. A carb would be your best bet in this case.
Quick Reply: cannot decide between carb or EFI
